Ongoing 2002 F250 Build 5.4L -> 7.3L Swap
#137
Ok so have not been home for awhile bu got out to the barn this past weekend and started cleaning up the engine. Pretty sure the turbo was leaking as the valley was full of oil and the orings on the pedestal were not seated.
Need to get an oil pan order and replace that since the engine is out and then finish cleaning up the bottom of the block. There was a gasket leak on the current pan and it is about rusted through.
#138
#142
Ok so I need a new oil pan, gasket, dipstick tube, dipstick tube adapter and hardware. The best pricing I have found are the following:
1999-2003 Ford F250 Super Duty Oil Pan - Engine Mechanical - Dorman 99-03 F250 Super Duty Oil Pan - 5337-05245511 - PartsGeek
00 2000 Ford F250 Super Duty Oil Dipstick Flange Repair Kit - Engine Mechanical - Dorman - PartsGeek
http://www.ebay.com/itm/NEW-OEM-OIL-LEVEL-DIPSTICK-TUBE-FORD-E350-E450-E550-ESD-EXCURSION-F-SERIES-SD-/231231692594?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d67b9f32&vxp=mtrMoroso 27293 Moroso Ford 7.3 Powerstroke & International T444E Oil Pan Gasket - Free Shipping on All Orders @ JEGS
Anyone know of better pricing?
#143
#145
#146
#147
Got some good work done on the truck this past weekend.
Toyman and I got my trans over to the shop to get the output shafts swapped out and have some valvebody upgrades done on Saturday morning.
Decided to go ahead and put a few coats of black enamel on the frame just to seal it up and make her last. Didn't turn out too bad not a fan of the gloss but wont see it anyway.
Fedex and UPS made their respective deliveries throughout the week so I had the new oil pan, gasket, and dipstick to install so I decided to tackle that.
Got the old pan off and the surface cleaned of all the old RTV that was left and started taking a peak inside.
Hello forged rods!! and nice to see some cross hatch on the cylinders still.
Since the Moroso gasket is thicker it came with studs for the block to replace the pans mounting bolts.
Once all the studs setup with the thread locker I got the new reusable gasket and pan mounted up good as new.
Next part I started to tackle is the new underhood wiring harness install.
Got most of it hooked back in and ready to go.
Finally I decided to replace the left valve cover due to it starting to rust and separate on me. Wasn't leaking yet but just to be sure.
Once the cover came off I was greeted by what appears to be all original sticks! AD1831551C1 and 55109497XXX where all XXX are within 100 of eachother. From driving the truck home and running tests before engine pull I know they are still running strong.
Ordered a brand new valve cover that should be here this weekend to replace it.
Also placed an order from Clay for the turbo install kit and new doghouse seals as well as my new A-pillar pod. So i should have another round of updates this coming weekend to install and get that much closer.
This is how its sitting now.
#149
#150
