Rocker panel, floor pan, cab mount replacement - Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
Old 04-22-2014, 10:45 AM
mgeorge0090's Avatar
mgeorge0090 mgeorge0090 is offline
mgeorge0090 is starting off with a positive reputation.
I am new to body work and have a couple of questions. I have a '69 F100 Flareside. My rocker panels, floor pans, and front cab mounts all need replaced.
1. What order should I replace them in? I was thinking rockers, mounts, pans.
2. If I leave the cab attached to the frame when working on the rockers, should I still brace the cab? If so where? I assume in the door to keep the cab bottom from coming together.
Any information or pictures would be great.
Thanks
Old 06-05-2014, 10:54 PM
D & D's Avatar
D & D D & D is offline
D & D is gaining momentum as a positive member of FTE.D & D is gaining momentum as a positive member of FTE.
I am welding my drivers side up right now.
I removed the floor pans and cab mount in one piece. Also replaced the driver side kick panel. When you cut it apart, you will see what is layered on top of what.
I am replacing in this order
Kick panel
Top front of rocker panel
Strip from rocker panel across kick panel and up to firewall (for floor support)
Floor board
Cab Mount
I am leaving the passenger floor and cab mount in until I get the drivers side done. That way, I can bolt up the passenger side mount and two rear cab mounts in order to place my drivers side cab mount in the correct position.
Old 06-07-2015, 02:16 AM
Jrgunn5150's Avatar
Jrgunn5150 Jrgunn5150 is offline
Jrgunn5150 is starting off with a positive reputation.
I was just wondering this same thing... Sometime this summer I'll be doing cab mounts, floor pans, inner and outer rockers, front door pillar, and even some pieces up beyond the floorpan/firewall flange.
I was going to do the same thing, just cut it all out, Jack it up level, and do one side at a time.
Any reason not to do it this way?
Btw, I'm working on a 1975 F100 4x4.
rust never sleeps!!! hch60 1957 - 1960 F100 & Larger F-Series Trucks 0 01-02-2017 10:34 PM
Complete floor pan assembly grant huggins 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-25-2016 08:36 PM
Crewcab rocker panels Johnny L 1987 - 1996 F150 & Larger F-Series Trucks 6 08-16-2014 05:59 PM
how to replace rocker panels FORD E-150 Paint & Bodywork 7 07-16-2012 11:47 AM
replacing floor pans/cab mounts some help crazed87bronco 1967 - 1972 F-100 & Larger F-Series Trucks 17 11-08-2010 11:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
