I'd like to replace my air pump with just a pulley to eliminate it or can I just gut the insides of mine. It makes a weird sound on startup and I think while driving.
Serpentine belt
Hey! Another Islander! I'm just a bit north of you!
I'm looking to do the same. If you search I posted a question about this a while back, and there were some good replies. Mine makes noise too. Sounds like a rod knocking in the engine, but its not...
Never heard that term ever.
Finally got it bypasses with a shorter 90.5" belt.
Didn't even remove air pump. Just took out bottom 2 bolts , loosened the top pivot one, pushed hard out of the way and cranked down bolt. Loose bolts went back in holes so if I ever needed I'll keep old belt behind seat and put it all back together.
