Radiator shroud 1966 F250
Old 04-21-2014, 06:17 PM
pm042070's Avatar
pm042070
pm042070 is offline
Does anyone know where a custom radiator shroud could be made? I have 3 electric fans on my 4 row radiator in my 1966 F250 with a 460 engine. Not a lot of room to work with In between the engine and radiator. Engine runs very cool on highway but runs a little hot in town in summertime. Doesn't overheat but just runs a little hot. Any information would be appreciated. Thanks!
Old 04-21-2014, 07:09 PM
diesldoct's Avatar
diesldoct
diesldoct is offline
If your running electric fans you shouldn't need a shroud
Old 04-21-2014, 10:08 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by pm042070
Does anyone know where a custom radiator shroud could be made? I have 3 electric fans on my 4 row radiator in my 1966 F250 with a 460 engine. Not a lot of room to work with In between the engine and radiator. Engine runs very cool on highway but runs a little hot in town in summertime. Doesn't overheat but just runs a little hot.Thanks!
On my 1965 F100, I used the shroud from a 1968/76 F100/350 360/390 without the Super Cooling radiator.
It bolted on like it was made for it.
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud / Marked at upper left corner: C8TA-8146-S or D3TA-8146-DA / Reproduced
Carpenter has repro'd this shroud, it's listed in his 1967/79 truck repro catalog along with the dimensions.
Old 04-22-2014, 06:00 AM
pm042070's Avatar
pm042070
pm042070 is offline
Thanks! Will try that shroud.
shark25
11-24-2017 11:38 AM
f-250.4x4.390
10-28-2014 05:20 PM
bicyclemonkey
16
09-15-2009 09:58 PM
sons73
05-04-2008 12:55 AM
fordtruckn
10-26-2005 11:49 PM
Quick Reply: Radiator shroud 1966 F250
