HOWTO - Add LED Lights
#31
Ive done LED conversions but wanted to ask if anyone ever swaped out a 90 series bulb for a LED version which is a 1142 bulb also known as a BA15D socket. I cant do a ebay search for just BA15D as I get dual filament 1157 bulbs not a single filament style 1142 bulb. Anyone have any luck with finding theses? I found one at www.superbrightleds.com but I haven't purchased from them and I tend to go towards ebay as I can some times luck out and get a bulk pack.
#32
I used the 67-x15 from SuperBrightLeds (probably the same one you found) in amber for my cab clearance lights. They work well and I have the peace of mind knowing I'm not going to have to go up there and change them anytime soon, that's a pain.
I also tried a BA15S-9SMD-WM from Hi-Po Parts for the courtesy lights under the dash. At the time I bought them years ago, they only had cool white, and I don't really like it, it's almost blue it's so harsh. They now have a warm white version (on that same page). Downside, these cost $8 apiece which is crazy, but they are very bright.
I'm sure you can find some on eBay. Instead of searching for BA15D (the "D" is for dual), do a search for BA15S ("S" for single filament). Also, it's 1156 for the single, not 1142.
#33
Really? I thought the D was for dual contact and S for single contact. I will try that. I purchased the following last night with two NOS inside door handles.
http://www.ebay.com/itm/10-PCS-Super-White-BA15D-27-SMD-5050-LED-Light-bulbs-Marine-Boat-1142-1178-1130-/201137947927?hash=item2ed4c18517&vxp=mtr
I am afraid they are going to be too tall for my application but for a under hood troubleshooting light I want as bright as possible that will fit.
THe one I found that would work that I found on superbrightleds is 1142-x12-G but its only rated at 68 lumens which I am afraid would be just as dim as the 90 series bulb.
But I will try doing a search for BA15S and see what I can find. It just hard as this is an oddball bulb cause it has dual terminals at the base with straight inline pins and one terminal is + and the other is -. Most of what I find under BA15D is 1157 type bulbs that the two terminals are + with the side being -.
#34
But I Googled 1142 and I see what you mean about double contacts on the bottom even though the bulb is single intensity. I don't think I've ever used such a bulb before, and I didn't know the 80-86 trucks had one anywhere. Sorry for leading you astray.
#35
i have read about the bulb swaps and done a few of my own on previous vehicles. i'm building a stakeside flatbed for my 85 f150. i will be installing some 6.5" LED oval brake/turn lights w/ 3 wire hookup as well as same sized LED reverse lights. i havent purchased the lights yet as i havent finished the fabrication work. once i do, will i need resistors to complete the install? i still have stock park/turn lights up front. just curious if i'll be able to wire in the lights without the hassle of the load resistors and extra wiring. anyone know by chance or have suggestions?
#36
#37
#39
Thanks, yes the upholstery is custom. I'm not sure which LMC item you're referring to specifically, but everything is holding up fine.
But the truck has a dedicated thread and it would be better to pose questions over there, and keep this one just to LED lights.
#40
#41
Offio
#42
Map Lights
Someone asked me about the map lights. These are the two bug-eyed holes in the dome light assembly. Here is what I said:
Yes, you could use an LED bulb for the map lights, and I tried, but I never found one that improved on the incandescent.
Strangely SuperBrightLeds doesn't really have any good ones that would fit, you can browse their BA15S 1156s here and see for yourself.
I did try this guy from Hipo Parts Garage (the same place that sells the convenient Ford parts CD): BA15S Base 9 SMD Courtesy Light Bulb.
But comparing it to a regular incandescent, the incandescent seemed brighter. Not bright mind you, just brighter. The map lights are kind of a poor design no matter what.
The problem with the map lights is that A) there isn't a lot of room in there and the really bright LED bulbs are oversize, and B) light only comes out a single, small hole where the lens is, and many LED bulbs (like the Hipo one above) are not very good at putting out uni-directional light. The Hipo bulb only had one or two LEDs that were actually facing the lens hole once you got the thing in there, and most of the rest of the LEDs were wasted shining in other directions.
So long story short - I'm keeping the incandescents in the map lights. They are kind of a pain to change, but hopefully they won't burn out very often since they won't get used very often.
But, if anyone finds a good upgrade bulb for the maplights, please post it here! We'd all be interested to know. The more light the better.
I replaced the lens completely with these:
Black Mini Roof Ceiling Lights
Very bright, gives excellent light to the side of the cab selected. Does require some wiring into the existing light fitting.
Lights up the inside of the center console as well.
#44
Just took the original lens out and they fit.
I'll get some photos tomorrow 11pm here now, would be good for showing how well they light up but not how they fit.
