7.5L engine with PaXton supercharger - Ford Truck Enthusiasts Forums
Old 04-21-2014, 02:39 PM
Brian75137 Brian75137 is offline
Brian75137 is starting off with a positive reputation.
Smile 7.5L engine with PaXton supercharger
Does anyone know if someone has melded a Paxton Supercharger to a 7.5L engine and then run it on propane. This is what I want to do for a '97 F250 supercab longbed truck.
I have reworked the engine as follows: (1) bored out 0.060 oversize, (2) flat top pistons, (3) Lunati cam, (4) gear drive for the cam, (5) 4-bbl intake manifold. (6) rear sump oil pan, (7) roller tipped rocker arms and (8) Ford cast aluminum valve covers.
I had converted this engine using an IMPCO mixer and a VFF30 lockout. The engine was used in a '78 Lincoln TownCar and I was reallly happy with it's performance. I opened up the engine at 229K miles and there was NO gunk under the valley pan.
Now I want to put this reworked engine into a '97 F250 (the last year that Ford put a 7.5L engine into anything) and add a Paxton supercharger.
I know from previous reading elsewhere that you blow propane through the mixer rather than suck through it so I plan to use a Paxton for this. I'll probably have to create my own plumbing for the air from the Paxton to the Impco mixer. Propane is about 110 octane, so I shouldn't have a problem with the increased compression (original engine had dished pistons)
From reading on this site, I see that an MDS ignition unit is highly recommended and I know that I'll have to use special spark plugs (probably platinum tipped).
I also plan to use some sort of free flowing cat converters and 3 inch exhaust pipes which will be set up an exhaust stacks (mounted vertically through the front of the truck bed). The propane tank (30 inch diameter) will also be mounted at the front of the bed between the exhaust stacks, thus centering the additional weight of the tank. I hope get about 400+ HP out of this setup.
I'm trying to find out if anyone has ever done this, and to get any other helpful information. I need lots of comments.
Project truck, opinions welcome Brian75137 1997 - 2003 F150 3 07-27-2014 02:39 AM
Paxton Novi-2000 Supercharger Kit for 98-01 V10 6.8L bolowc Ford Truck Parts for Sale 0 06-20-2014 05:46 PM
NEED HELP.. MILD TURBO PROPANE 5.4 TRITON FUEL SIPPER BUILD DAKIND1 1999 to 2016 Super Duty 8 01-06-2013 01:20 PM
77 f150 on propane and turbo munts77 Ford Inline Six, 200, 250, 4.9L / 300 7 08-30-2012 08:23 AM
propane performance kenjh Alternative Fuels, Hybrids & Mileage 12 05-11-2010 11:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
