6.4 Air in fuel - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 Air in fuel
Old 04-23-2014, 06:07 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Yes actuator should cycle. check the electronics to ensure proper connections.
Old 04-23-2014, 06:38 AM
Mudslinger72315's Avatar
Mudslinger72315 Mudslinger72315 is offline
Mudslinger72315 is gaining momentum as a positive member of FTE.
I thought so. It is not cycling and I can move move it freely while the key is on. I am hoping maybe I have a blown fuse somewhere or something. I wont be able to look today because I will be out of town with work until Thursday evening, but please, if anyone has any suggestions, please throw them my way. Updates:
I installed the body bolts, hoping it was a grounding issue, same result.
The only scanner I have is my super chips. Even after I clear the codes, the wrench still displays in the console.
Old 04-23-2014, 07:19 AM
senix's Avatar
did you by chance remove the wiring harness from the connectors by the airbox? If so could you have a pushed in pin or maybe a bent one.
Old 04-23-2014, 11:30 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
FYI, Mine has the cable pulled right off the turbo VVT controller,
it triggers the engine light, but truck runs and starts 100% fine.
Old 04-24-2014, 12:17 PM
Quote:
No, I only unplugged the Actuator.
I agree that it would start without the actuator connected, but since mine is connected and not cycling, it points to something else being wrong. I am going to check every fuse in the truck tonight and see if I can figure it out. Maybe a fuse to the PCM or something.
Old 04-24-2014, 10:33 PM
Ok, good news bad news. Seems like my life is full of that. The good news is, I got it to start. Fuse 72 was blown. Replaced it and she purred like a kitten. Bad news is, apparently the oil drain on the bottom of the turbo did not go together right and she started proceeded to pour several quarts of oil onto my shop floor. Oh well, its not like I've never taken my turbo off!
Old 04-25-2014, 05:18 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
LOL, Oopps, I didn't say that did I.
Man you are going to be an expert at this Turbo removal/ installation by the time you get this thing wrapped up.
Old 04-25-2014, 06:09 AM
senix's Avatar
I think we have all been there done that. It will be easier to fix this issue.
Old 04-25-2014, 08:31 AM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
Quote:
Originally Posted by Mudslinger72315 View Post
No, it isn't running yet. Trust me, I am ready too. It's going to feel like a new truck when I get it going. I am home now and I cleared and ran the codes again. They are as follows: (new ones showed up)
P-1000 Mass/volume air flow circ range/perf
P-179a
p-0488 EGR throttle pos ctrl (I know why this one is here)
p-0091 Fuel press regulator ctr circ low
p- 0003 Fuel Volume Regulator ctrl circ low
p - 0670 glow plug ctrl circ error
p- 0684 glow plug ctrl mod to pcm circ range/perf
and p-1000 monitor checks not complete.
Should it still start? I am not laying on the starter any longer than 20 seconds or so.
Also, I remember reading a post that someone had some kind of a no start issue and it ended up being his passenger side battery. My passenger side battery is bad (I have it disconnected and a battery charger/starter connected to it. Could that be my entire problem?
I will PM you my cell number. I can pull and install the turbos with my eyes closed now. I just need to learn diagnostics.
Hate to tell you this, but you might be in for some major work. Fuse 72 blowing and P0091 and P0003 tells me that theres something wrong with the circuitry to your high pressure pump usually the gasket with the pass through wiring.
Old 04-25-2014, 08:40 AM
Yes, I know that is typically what it means, but I am hoping that it is something I did while removing or installing the turbo. Also, it is a 20 amp fuse and all I had was a 15, and since it didn't blow immediately, I have my fingers crossed
Old 04-25-2014, 08:41 AM
Yes sir, I can almost pull the turbos with my eyes closed now.
2000 3.0 Ranger Injector Swap bigredtruck Ranger & B-Series 16 06-29-2016 10:24 AM
Truck Cranks but no start 1994 f150 Stratifiedjoe Ford Inline Six, 200, 250, 4.9L / 300 2 06-22-2016 02:06 AM
Truck Cranks but no start 1994 F150 Stratifiedjoe 1987 - 1996 F150 & Larger F-Series Trucks 12 06-06-2016 10:29 PM
Air in fuel system trouble TripTheDog 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-13-2013 10:32 PM
cant get my truck to start. Cobra Highboy 1994.5 - 1997 7.3L Power Stroke Diesel 15 09-05-2013 02:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
