53 merc 1 ton with a cummins?
I agree with everyone else on keeping the Merc frame and body, but that Cummins with trans is very heavy (+1000#). The frame will have to be reinforced considerably. It will be a real stump puller but it will have lots of handling issues. AX won't have to worry about any autocross competition.
Please take pictures of the shop before you fill it up... and after ... we love pictures.
A person would have to check into this but a mechanic/Cummins fanatic friend of mine says the early Cummins ways far less (150 lbs more than a 440) than a late one and if a auto is used (727 with an od) shouldn't be that heavy.The cast iron 5sp is heavy.The newer style is a couple hundred heavier than the gen one Cummins.
http://en.wikipedia.org/wiki/Cummins_B_Series_engine
engine weight difference - 440 and Hemi
And here are some of the year to year differences:
http://http://www.allpar.com/mopar/cummins-diesel.html
440 weighs 670 lb and Cummins 6BT is 1100 lb dry weight
Cummins B Series engine - Wikipedia, the free encyclopedia
I was sure that was correct as I was in Jeep and Truck Engineering (JTE) at that time and we couldn't put the engine in late 1980 4WD trucks due to the weight on the front axle.
