03 6.0 rough idle issue - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-20-2014, 10:55 PM
af11 af11 is offline
af11 is starting off with a positive reputation.
I just got an 03 6.0 and a few days ago it developed a rough idle, it takes a little longer to crank and idles fine for 30 seconds to a minute then the rough idle kicks in also I noticed when I drive it the low rpm range is a little choppy and when I come to a stop it goes a little below idle then resumes the rough idle issue. I had it die on the road a day prior to this after it lost complete power at a red light, it started to idle low so I tried to counteract with a little throttle and with the throttle all the way it did nothing, a few minutes it died on the road and took a few minutes to start back up I did a set of filters and it hasn't done it again but I still have the rough idle, I checked the icp sensor and wiring no oil so I cleaned it up a bit and it runs a little smoother but want to know if anyone might have any other suggestions.
Old 04-20-2014, 11:05 PM
89stinger's Avatar
89stinger 89stinger is offline
89stinger is starting off with a positive reputation.
Hi af11. My 03 6.0 did the same thing.... the first time it was the icp sensor. Second time it was the HPOP. The third time it did it it was the FICM. ICP sensor doesn't have to leak to be bad. Just my 2 cents
Old 04-20-2014, 11:38 PM
Which reminds me I do have an oil leak I haven't tracked down yet it's on the back of the motor up top I just need to get some time to look at it well. Any idea what it might be, I've got a lot of experience with the 7.3 but they don't have issues like the 6.0 does
No power, dies once up to temp but restarts fine Tim.oconnor2 6.0L Power Stroke Diesel 5 01-06-2016 08:48 PM
truck dies with low icp pressure after bulletproofing TheBlueMule 6.0L Power Stroke Diesel 35 07-11-2015 03:39 PM
No throttle, no power, no pulsing gtkid2002 6.0L Power Stroke Diesel 22 11-11-2014 06:48 PM
Advise for future of my 2007 6.0!!! mahd776 6.0L Power Stroke Diesel 2 02-01-2014 09:53 AM
2007 6.0 out of the blue problem???? mahd776 6.0L Power Stroke Diesel 3 01-30-2014 07:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
