6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Which Programmer with DPF delete
Old 04-20-2014, 08:34 PM
ZPI28's Avatar
ZPI28
ZPI28 is offline
Hello FTE , I just recently purchased my second Dually. 08 4x4 King Ranch with 164K miles on it. Its still completely stock except for a 6" RC lift with 35" Fuel Offroad mudders. I have read the carfax and the first owner was commercial and 90% of the miles were put on then. It had the radiator done at 30K miles. I drove it back from Dallas to Northeast Arkansas and averaged 11.5 mpg with the lieometer. I am looking to do the DPF delete and try to get a couple more MPGs out of it. Not looking for alot of power, this one has plenty compared to my 01 F350. Just want a little better economy and to be able to correct my speedometer for the tire size. Thanks
Old 04-21-2014, 10:40 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Personally I would search Craigs list to try to find a pre EPA H&S tuner, also try searching Ebay of Canada, you might find something worth buying.
Bunch of places are selling H&S that must be made of the country or their doing some programming to them, but they don't come with the allotment of tunes the old ones came with, they probably would be OK??
Old 04-21-2014, 10:52 AM
Mudslinger72315's Avatar
Mudslinger72315
Mudslinger72315 is offline
If you are mainly just wanting to do the DPF delete without power gains, you could go with the DPF-R from Gearbox-z. It is fairly inexpensive, (about $400 bucks) plus the exhaust pipe of your choice. (By the way, hello neighbor)
Old 04-22-2014, 09:54 PM
ZPI28's Avatar
ZPI28
ZPI28 is offline
Ive looked at the Gearbox Z. It would do me good on the DPF but Id still need to get something to correct my speedo.
Hello Mudslinger fellow Mississippi County Neighbor
Old 04-24-2014, 09:59 PM
URDADDY's Avatar
URDADDY
URDADDY is offline
gearbox is junk IMHO. Will trash your tranny.
Old 04-28-2014, 11:25 PM
aquaman's Avatar
aquaman
aquaman is offline
H&S, Spartan and DPF-R seem to be the better choices. However don't set expectations too high on the mpg gains. To be realistic, you'll see savings from no more regens and maybe 0.5-2mpgs at best from what I'm gathering...depending on how you drive, of course. H&S will let you modify tire size
DPF-R doesn't mess with your shifting; it keeps the existing factory shift schedule untouched.
Old 04-29-2014, 05:13 AM
senix's Avatar
senix
senix is offline
Received 1,414 Likes on 1,009 Posts
Your biggest issues are gearing and the lift and bigger tires. If you have a net gain of 1 mpg I'd be surprised to tell you the truth.
I go gearbox z with the no power (stock) setting. You will need a monitor as well.
Old 04-29-2014, 03:24 PM
ZPI28's Avatar
ZPI28
ZPI28 is offline
2 mpgs would be very welcome. I know this setup is not for mileage. Thanks for the inputs. Something simple that doesn't mess with the transmission would be fine.
Julio Casarez
2017+ Super Duty
10-06-2018 12:53 PM
jays power stroke
01-20-2007 05:47 AM
acm05fsu
1997 - 2003 F150
12-06-2006 08:18 PM
sawfish99
09-02-2005 09:44 AM
digracer
16
06-05-2005 07:26 AM
Quick Reply: Which Programmer with DPF delete
