What PN gas lift gate struts? - Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Old 04-20-2014, 07:58 PM
John R. Thomas John R. Thomas is offline
John R. Thomas is starting off with a positive reputation.
Ref. 70s Ford cap with original sliding lift gate struts: I am replacing my
fiberglass lift gate that is broke in 3 places with a identical lift gate.
I intend on replacing the sliding struts with gas struts. Length: Max 14", Min 7.5". The total weight is 40 lb.
What brand, part number and store/web sight is suggested?
Since writing this request, 29 Ford truck owners have read it and no one has done the research.
I emailed a manufacture the same question. No reply either.
Old 04-23-2014, 04:47 AM
-mywheels- -mywheels- is offline
-mywheels- is starting off with a positive reputation.
I would take one of the sliding liftgate props with you to a "good" auto parts store. They can measure the length of extension and retraction and suggest what would work best. I am staying all original with my canopy/camper. Jeffs bronco graveyard sells the sliding liftgate prop in their bronco section. 77 and earlier Bronco and canopy props are the same.
Old 04-23-2014, 08:02 AM
There's a reason for the swap to the gas cylinders (struts). I left my lift gate open as I often did
with my 59 Ford wagon. Crossing railroad tracks, the lift gate jumped and came down
on one side. The fiberglass frame broke in 3 places. I bought a complete Ford cap that
sat in the grass for years. The lock and latches were rusted solid. The screws had to be
drilled out. Gas struts of the proper strength should keep it open and not mess up when
I want to close it. (locked up on one side then the other etc)
I have emailed STRONG ARM GAS LIFT SUPPORT twice with the info for a quote. ( total wt. 40lb. Max 14" Min 7") No reply yet.
Old 04-23-2014, 07:43 PM
Today I visited my local Advance Auto Parts store and their catalog for Strong Arm.
If the min. length is 7" the max. is only 10" Therefore, the lift gate hits me in the face.
Oh Well. Perhaps that's why no one has installed gas struts on their Ford cap lift gate.
Rear lift gate struts which brand to buy?? radmacks Excursion - King of SUVs 5 03-14-2016 11:26 AM
EZY-LIFT Blue7.3 Australia Chapter 11 10-19-2014 04:48 PM
95 Aerostar hatch/liftgate struts/cylinder failing? f64 Aerostar 4 03-30-2011 08:30 PM
Rear Window Lift Gate Issues... epfire#233 Excursion - King of SUVs 12 01-21-2011 07:26 AM
'01 rear lift gate struts ramblemutt Excursion - King of SUVs 10 12-23-2010 01:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
