What RABS computer can I use? - Ford Truck Enthusiasts Forums
Old 04-20-2014, 06:41 PM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
I pulled a dash wiring harness from a 93 and it also has the RABS computer. How do I identify this computer to know if I can use it on my truck? Will any RABS work?
Old 04-20-2014, 07:23 PM
wag53's Avatar
wag53 wag53 is offline
wag53 is starting off with a positive reputation.
According to my books, '93 was change to RABSII module numbers begin with F3TF-2CO18 or F3UF-2CO18 other module numbers are RABSI. Doesn't appear that they will interchange.
Old 04-20-2014, 07:30 PM
RIKIL's Avatar
I've got to think this is RABS, I also pulled the RABS valve from the same truck and it looks exactly like mine.
Here is the unit I have - http://i.imgur.com/MkWlM0M.jpeg
Old 04-20-2014, 07:54 PM
RIKIL's Avatar
I guess what confuses me is where it says single rear wheel only. And I did visually verify the RABS valve on my truck is the same as what I pulled from the same truck I got the harness from
Old 04-20-2014, 08:12 PM
wag53's Avatar
That seems to be a RABSII module, the single wheel only means not for a dually. That is the same as mine ('93 RABSII).
Old 04-20-2014, 08:32 PM
RIKIL's Avatar
That makes more sense
You happen to have a wiring diagram for RABSI and RABSII that lists what each pin is for? I'd like to understand the differences
Old 04-20-2014, 09:06 PM
wag53's Avatar
Can't find one for RABSI but here is one for RABSII might help
i
ABS and brake light on fordguy4life Aerostar 22 09-27-2016 08:50 AM
92 F-150 Rear ABS light Runfox 1987 - 1996 F150 & Larger F-Series Trucks 7 02-17-2013 12:28 PM
Aerostar RABS hartski Aerostar 10 07-30-2012 02:21 AM
Master Cylinder Question MARC96 1987 - 1996 F150 & Larger F-Series Trucks 2 07-22-2012 11:21 AM
Symptoms of bad RABS valve ?? krl13 Brakes, Steering, Suspension, Tires, & Wheels 1 07-30-2008 08:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
