Aftermarket Trans coolers for E40D
I prefer the sender be in the pressure test port. That is on the driver's side of the trans, just above the pan, towards the front of the trans. There is a black hex head plug there from the factory.
Adding a port to the pan adds a potential leak point, but more importantly, reading the temperature down low in the pan will show you the coolest spot in the entire trans. It's where the cooled fluid that has just returned from the cooler is located.
smash fascism
01-11-2019 07:07 PM
mxracer3276
02-22-2010 07:11 AM
