starts once a day for about 30 seconds
okay I got an 06 F 350 Super Duty 6.0 the last week on my way home from work it lost power temporarily and then it was fine...the next day drove it to work....didn't have any problems...went out to start it after work it ran for about 30 sec. and died..towed it home and i can start it one or twice each day for about a 20 to 30 sec....took upper fuel filter cap off tuned key fills really fast....checked icp with volt meter and wen running it was at .98v and need to know wat to check next
you need a Gauge
sounds like HPO Problems
BUT could honestly be anything at this Point
Autozone sells a ScanGaugeII you need something to see live data
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
If you can get one it would help Tons
Its Lots harder to diagnose without a Gauge
One thing you can check is remove the Oil Filter cap and Crank the Oil Filter house should fill fast does yours??Do you see OK Pressure on the LPO Switch on Dashbosrd??
