65 F100 Owner Charlotte - Need Mechanic for 2d Opinion - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Old 04-19-2014, 11:51 PM
jpoesq1's Avatar
jpoesq1 jpoesq1 is offline
jpoesq1 is starting off with a positive reputation.
My 1965 F-100 has a replacement 352 V-8 of unknown vintage (likely late 60s or 70s). It has been diagnosed as having a bad #8 cylinder, recommendation to rebuild. The quote to rebuild was about $7,000 all-in including some additional stuff tossed in. At that price, I have to sell the vehicle and if I spent that kind of money, I would think replacing the engine would be the much smarter play. I need help to assess the options and decide what to do. Anyone have a guru with whom I can connect?
Thanks.
Old 04-20-2014, 11:17 AM
ubereal2's Avatar
ubereal2 ubereal2 is offline
ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.
Why is #8 bad?
And yes, $7,000 is crazy money, if you want a fresh build engine, price "Long Blocks" at about any auto parts place.
Old 04-20-2014, 11:35 AM
77mud's Avatar
77mud 77mud is online now
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
I believe Id get a second estimate from someone else....
Old 04-20-2014, 09:14 PM
jpoesq1's Avatar
Any suggestions?
Old 04-21-2014, 03:45 PM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
All I can say is $7000 to rebuild an engine is outrageous. I know it is a 352 but they aren't that different to cause that much of an increase in the price. You can get a new engine installed for a little over half of that. I would call around to a few machine shops and ask what they would charge to do the work on the engine. 7 grand is rediculous.Someone also ask before what did the shop mean by #8 cylinder is bad? I am a fleet mechanic (ASE Certified) and that price sounds way over what it should be. Even if the cylinder wall is cracked they could sleeve it and it shouldn't cost that much. I wish I knew of a shop in your area.
Old 04-21-2014, 09:48 PM
ncheavymetal's Avatar
ncheavymetal ncheavymetal is offline
NC Chapter Czar
ncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to behold
From Ratsmoker:
Quote:
I'm assuming you are going to bore the block since you are looking for a rebuild kit. Autozone sells badger pistons for about 100 bucks a set up to .110 over for the 352. I would then get the bearings and rings from summitracing. Go with a good brand on these as this is where you want your strongpoint to be. A cam & lifter kit can be bought from autozone or PAW very cheaply. May as well rebuild the carb too while you're at it. It will cost about $20. All your gaskets can be bought from summitracing or autozone for about the same price. I would recommend felpro's engine rebuild kit. It will contain about everthing you will need. Autozone will also trade in your heads for rebuilt ones for about $125 a head if yours need too much work. I don't know how good their head work quality is but people tell me it is ok. Head work can get expensive if you start talking new valve seats and guides. Don't forget to do your oiling mods as they are cheap insurance. I would say a HV oil pump is optional if you aren't going to be revving the motor all the time but replace the oil pump reguardless. ARP makes an oil pump driveshaft for about $15 bucks that is pretty much invincible so that would be cheap insurance also. ARP rod bolts is another strong recommendation. They are far stronger than ford's bolts and cost about $50.
It also may be a good idea to pose your question here:
FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) - Ford Truck Enthusiasts Forums
Good luck. Keep us posted.
Old 04-22-2014, 07:15 AM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
fuzzy1626 is gaining momentum as a positive member of FTE.fuzzy1626 is gaining momentum as a positive member of FTE.
A junkyard Coyote would be nice in that truck.
Old 04-22-2014, 08:31 AM
ubereal2's Avatar
Quote:
Good call Tony!
Old 04-22-2014, 08:33 AM
ubereal2's Avatar
Still no reply on why #8 is bad...
Old 04-22-2014, 11:37 PM
wp120470's Avatar
Well he can't say the Q-Crew wasn't there for him.
Old 04-23-2014, 10:02 PM
jpoesq1's Avatar
Thanks guys - to answer the question about the #8 cylinder, in short I dont know. I think that he said that when he took the head off he could see material bled over from the #7 into the #8, but I could be totally wrong. As it is, I have the vehicle with a mechanic here in CLT who does NOT think the engine needs to be rebuilt so I am having some small work done and we're going to see what comes out.
Old 04-24-2014, 08:06 AM
ubereal2's Avatar
I'd start with a compression test of all cylinders... A vacuum test wouldn't be a bad idea either.
Newb from Charlotte checking in! 70Bumpside New Member Introductions 1 01-08-2016 02:39 PM
Adios....for now (aka Sad Day for PSD Owner) mjunk1 1994.5 - 1997 7.3L Power Stroke Diesel 14 07-07-2015 10:52 PM
Greetings from Charlotte, NC AirCav New Member Introductions 3 06-03-2015 12:26 PM
**SOUTHERN TRUCK ALERT**Help A Fellow FTE Member!! WoodBoss 1987 - 1996 F150 & Larger F-Series Trucks 1 04-03-2015 02:28 AM
Mechanic Needed - Charlotte NC - '65 F100 jpoesq1 1961 - 1966 F-100 & Larger F-Series Trucks 8 04-23-2014 10:57 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
