Green aftermarket parts
We're aware of the issue and I'm sure others will chime also noting your issue.
It's a case of supply vs demand... green wasn't a popular color. A production run of green door panels or dashpads will cost more to produce due to its limited demand.. it'll be a low production number for sure because it'll sit on shelves for a longer time than black, blue, or red. And if the aftermarket does reproduce them, be prepared to pay a lil extra.
To the OP. What I have found is that carpet in green is available. Most upholstery shops can recover and reconstruct a dash pad or a seat in green rather affordably. There is a company on eBay that is selling green reproduction door panels for dentsides. They have a different shaped speaker grill and I honestly do not know anything about the color match or quality. You can get the correct color vinyl and plastic dye/paints at most autoparts chans if you want to try to make your own out of a new set. I have heard from buddys that black and blue cover better then tan. Hope this helps.
sum_weirdo
15
07-12-2007 09:50 PM
HiDesertRat
07-12-2004 06:24 PM
