Safety Recall 05S28
Safety Recall 05S28
Just thought I'd put this out there for you guys.
Ford recall notice 05S28 Speed Control Deactivation Switch Fire.
I just received this notice in the mail today from Ford for my 95 F250. It says that there is a potential fire hazard from the switch and it doesn't matter if the truck is running or not and it also doesn't matter if the key is in the ignition or not. It doesn't matter if the speed control system has never been used. They suggest that the vehicle be parked away from structures to prevent under hood fire from spreading until the repairs have been made.
It doesn't state what years are involved with this recall so I would suggest if you don't receive a recall notice to call the Ford customer relationship center at 1-866-436-7332 to see if your truck is involved with the recall.
All you need to do is disconnect the cruise control module and you'll be fine, that's what my mechanic did. It's cheaper than going to the dealer and being told there's nothing wrong with it and being charged 80$ to get it inspected.
Here is a detailed description of the recall:
Recall ID # 61635 - VEHICLE SPEED CONTROL
I wondered what that pig tails was. I thought it was something the p.o. did. That's their solution to a potential fire incident. What a crock of s***. A non serviceable fuse? Is that vs on when the fuse pops they can say they did the recall work and now you have to purchase another pigtail at a crazy price?
The recall involves replacing the brake pressure switch and installing a fused harness. The recall is free, and should only cost you the fuel to drive down to the dealer. That fuse should never, ever have a reason to pop. If it does, something is seriously wrong with your brake pressure switch. That's why it doesn't need to be serviceable.
I just got this notice today for my 2003 E250. Glad you have this thread here... wasnt sure what to make of it... and you never know what type of micky mouse fix they come up with... some are good, some just flat out hurt the vehicle.
I think I will see about getting this one done... I use my cruise all the time.
white Buffalo
78
11-06-2009 11:03 PM
madsonp
1997-2006 Expedition & Navigator
48
08-09-2008 09:58 PM
dan1101
03-27-2005 07:36 PM
