2004 Ford e350 V10 Engine Making noise..
Hello All!
Someone on youtube said it could be a plastic baffle that broke due to low quality underneath passenger side valve cover
vigorously maintained . 150,000 miles.
Any suggestions? Im living in this van due the economy...
Thank you in advance!
Whom ever finds the problem or assists whole heartily I promise a free vehicle history report.
Video
Hello All!
Video
That PCV baffle has plastic rivets that break off and allow the baffle to move around the valve train. This can cause damage. I would remove the valve cover and pull the baffle out for now until you can repair it. Valve covers are on national back order. Check the looseness of the timing chain while you are in there.
HOw does one get access to remove the Valve covers? I am use to working on Toyotas .......
http://i.ebayimg.com/00/s/MTUwMFgxMT...TETkR/$_57.JPG
thanks GFL and Jessie, I appreciate the efforts and look forward to figuring it out.
So iam looking for a splash guard?
>if I remove the Oil Spout with the 1 clamp on the VC would I be able to see anything or do anything?
Here is another VIDEO
I dont know if yours is like mine, but the pvc valve is about in the middle of the passenger side, it just pushes into a rubber grommet on the valve cover, under the valve cover is like a shield, which is what apparently can come loose from the cover itself and bounce around on your valves when running
no I don't drive it like that. I just started for the video.
justmosing
02-21-2018 12:35 PM
Dave Massingham
03-08-2014 03:00 AM
