battery light
Old 04-19-2014, 10:54 AM
haven56's Avatar
haven56
haven56 is offline
battery light
I was driving my 56 the other day and noticed the battery light was barely on at idle. As I would give it some gas the light got brighter. I'm running a 292 Y-block with a gm 10si alternator, It's been working fine for 3 years. I checked the voltage at the battery. With the engine at idle and electric fan off it shows 14 volts. With the fan on it drops to 13.3. At high rpm volts go up to 14.8 but that is when the batt. light is the brightest. That doesn't make sense to me. I took the alternator to the parts store to be tested, they said it tested good. Why is the light on when the volts never go below 12 ?
Old 04-21-2014, 12:04 PM
haven56's Avatar
haven56
haven56 is offline
Would this indicate that the internal regulator is not working right?
Old 04-21-2014, 01:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Almost certainly, but check the battery too (load test).
Old 04-21-2014, 07:18 PM
haven56's Avatar
haven56
haven56 is offline
Thanks for the reply. Battery seems to be in good shape, it holds a good charge and it's not giving me any trouble. The alternator should be putting out close to 14.2 volts almost all the time right? I'm still not sure why the batt. light is acting like it is.
Old 04-21-2014, 07:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I believe the light is hooked up with alternator output on one side, and battery voltage on the other. When they are the same, it is out. When either one is more than the other, it is on. Since your alternator is putting out more than battery voltage, it's coming on.
andym
05-19-2015 07:37 PM
brandon.edwards
04-28-2013 09:03 AM
chris86924
10-20-2010 02:43 PM
built tough
1999 to 2016 Super Duty
11-18-2007 12:50 AM
j_n_l
1997-2006 Expedition & Navigator
07-20-2006 06:48 AM
Quick Reply: battery light
