Baja Desings SII LED Reverse Lights
I had purchased these Baja Designs LED lights to use on the front of my dual sport, but I never got around to doing it. Instead of letting this sit any longer, I figured I would put them to use. These little babies are seriously potent for their size. The best part about Baja lights is there ability to be customized to whatever application you need them for.
I originally had the combo optics on these lights and switched them to a full flood optic for reverse purposes. You remove the 4 hex bolts to gain access to the optics. I pulled off both of the optics, one driving, one spot, and replaced them with two flood.
I hooked them to one of my upfitter switches, and I mounted them to the rear bumper support. I am extremely pleased with how they work. They are pricey, but comparable to rigid in terms of price. These are great lights that can be used in multiple applications.
Here is a pic of one SII light with flood optics vs combo optics:
They really light up the night.
I found the site and the price. $174.95
Baja Designs LED lights SII LED Combo Light
They have some really good looking stuff.
Sean
Sean
With these lights you could probably get away with one light for reverse and utility. I was actually considering turning them into fog lights and flush mounting them into the front air dam. I did get them for 10% off, if you mention you are a member of the forum, so now it makes more sense
If anyone boats, these babies would be awesome as utility lights!
Always helps to know people like that!! I have access to Rigids at a decent price so I think if I decide to go with something nicer I will eventually go that way.
