Gooseneck recommendations for F250 SB
Hi folks,
I just bought a 2005 F250SD diesel crew cab with the short bed box. Didn't realize how difficult this would end up being till now due to the SB box. I wanted the long bed, but got a really smoking deal on the SB. I'm looking to get a fifth wheel camper and want to tow it with a gooseneck hitch. I really prefer to not have to deal with the fifth wheel hitch in the box and having to remove it when I don't need it. I've called a few dealers around here, Denver area, and they all say they don't deal with goose conversions. I know it's higher here than it was not too long ago , but I don't think it's that high! I've seen people towing fifth wheel campers with SB trucks, so what gives? I've looked into the B&W and hide-a-goose but the measurements don't add up to give the recommended 4" clearance, even with the ball extenders.
What are people using? I have nothing in the bed of the truck now, so I'm open to anything. I also see that there are hitch pin extenders out there, not familiar with them(this will be my first fifth wheel). Is that the trick, ball extender mixed with the hitch pin extender? Can you even do that? Thanks for all the help ahead of time!
First, when we were shopping I thought I wanted a gooseneck since I already had the hitch in the truck. We found, however, that most trailer manufacturers don't recommend that conversion and in fact it may void any warranties there might be. Having said that we did go with the Companion Slider hitch. There are now some other options. Anderson makes a hitch now that lets you use the gooseneck without converting the fifth wheel kingpin. At least one member here has that type of hitch and will hopefully chime in.
This is my now gone '06 F350 and hooked up to our 34' 5er. It's a SB and using a B&W Turnover with their Companion hitch. Many trailers without the cutaway aero nose will need a slider which B&W now sells. I didn't need that type hitch though it was close. Bed to trailer clearance is +/-6 inches. As far as gooseneck adapters, most trailer manufacturers will not warranty their frames with that added lever arm.
This is as it was set up in the '06 truck:
Thanks for the info so far guys! That's a sweet setup Irelands Child! The warranty I'm not too worried about, we're looking at campers that are out of warranty anyway. It's a starter camper for us and not sure if the wife is going to really take to camping. Plus, I'm gonna be using it for Elk and other hunting trips so I don't want anything too fancy as it'll get all full of mud and stuff. I'm still hoping for a Hail Mary, but I'm thinking a fifth wheel slider hitch with an under bed mount, like senix mentioned, is in my future.
Here is a picture of the Companion slider that connects to the B&W turnover ball hitch that I have.
HouseMouse
Fifth Wheel & Gooseneck RV Towing
12-31-2016 08:59 PM
