Tank sending unit ohms? - Ford Truck Enthusiasts Forums
Old 04-18-2014, 08:39 PM
Juddpease Juddpease is offline
Juddpease is starting off with a positive reputation.
Any body know the correct ohm reading full and empty on a 64 f100 behind the seat tank. I don't see it in the shop manual I just bought. My gauge doesn't work but rises if I ground the wire off sending unit which makes me think its sending unit or float.
Thanks.
Old 04-18-2014, 08:43 PM
norfolknova norfolknova is offline
norfolknova is gaining momentum as a positive member of FTE.
If it rises when yo grond it then the gage is working, and it is probably 90ohms empty 0 ohms full. I would start ith pulling the sending unit and check the float. Also when you pull it you can cycle the float mechanis and watch the gage to see if it working, then you will know if it is the sending unit or the float
matt
Old 04-19-2014, 12:03 AM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
My 62 had the same problem found a hole in the float, corrosion from running the good gasoline we get. I have seen gasoline eat the steel inside a barge.
Old 04-19-2014, 06:31 AM
Thanks!
I'll take it apart and check it as soon as I can. I Need to weld the studs back on the vent window frames so I can get the door windows back in it first.
Old 04-19-2014, 12:04 PM
kjvforme's Avatar
The floats are cheap from NPD, or any other Truck supplier.
Help finding sending unit/gas gauge that are compatible. ford5.8 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-19-2016 07:18 PM
Aftermaket Sending unit bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-26-2016 01:43 PM
Testing Oil Pressure Sending Unit powells_f150 2004 - 2008 F150 0 06-30-2014 06:52 PM
77 f250 fuel gauge issues Hexes2007 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-31-2014 10:04 PM
fuel gauge 56 imlowr2 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-13-2007 06:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
