Time for brakes
Time for brakes
I've finally gotten settled in here in Florida... gotta say, my wife loves the weather here for sure!
I think it's time for brakes. I've put nearly 20k miles on the truck since I bought it in November, 2012, much of those pulling a 25k trailer. The truck is still stopping just fine, but I feel like it's taking too long to stop and I'm not sure I could stop on a dime like I used to if I needed to.
So current dilemma--to do them myself or take the truck to Midas?
Pros for doing it myself: Cheaper.
Pros for Midas: Lifetime warranty, and I no longer have access to my shop with floor jack, jack stands, air powered tools, etc...
Thoughts? If I do it myself, what do you guys recommend?
Good luck!
Well, you didn't provide enough information.
Take the truck to Midas and get the estimate for 4 new rotors + 4 new (loaded) calipers Installed.
Determine what they're going to replace. Will they just turn your rotors or will they replace them?
Will you get rebuilt calipers or will they just swap the pads?
THEN make the comparison.
Cheers,
Rick
I don't need new rotors... Just pads. And last time I looked at them they actually had a lot of life left on them, so perhaps it is just a fluid issue... The pedal goes down nearly to the floor also, so maybe there is air in the system? It's not low on fluid, I've checked that...
+1 Motorcraft pads. As for rotors (IMO) if your gonna do a lot of towing I would opt to replace my rotors rather than cutting. Only because it will make them thinner and thus heat up faster. But that's just my opinion.
You are suppose to service your brake fluid. After all it is an oil and with any oil it does break down with heat. I don't remember what the recommended interval was but if your fluid is brown and nasty looking I would flush the system out. Same goes for the p/steering fluid. The p/s fluid actually actuates you brake master (hydro boost) as in power assist like say a vacuum brake booster would work.
I have the MV7300, best 100.00 I've spent for a tool! Takes 15-20 to completely flush the brakes. I start with removing the fluid in the reservoir, refilling with new fluid, then starting with the furthest wheel from the reservoir and working your way to the drivers wheel.
BTW, having fresh fluid in there does make a huge difference in how the brakes feel...
Mityvac
Mityvac
