Turbo Compressor Housing - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-18-2014, 04:45 PM
Traildust's Avatar
Traildust Traildust is offline
Traildust is gaining momentum as a positive member of FTE.
I just changed out the stock compressor wheel for a Billet Wheel from RiffRaff. I removed the turbo to do this, got everything back together put my boost Leak Detector on and now have a leak at bottom of the compresor housing. When I put the housing back on the turbo I was very carefull to make sure I went by the numbers. My question, are leaks common around the compressor housing? I'll pull it back off and see what I can do.
Thanks All,
Bill
Old 04-18-2014, 05:04 PM
duck fan's Avatar
duck fan duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Double check that the compressor housing oring is still in place and not pinched in any way. Nice thing is, you can do that with the turbo still on the truck.
[video] Choppy exhaust sound , turbo or a leak 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-10-2015 12:55 PM
WTB: '05 Turbo Compressor housing dflack001 6.0L Power Stroke Diesel 10 11-02-2014 08:46 PM
Turbo talk, I have un-answered questions diehardstroker 1999 - 2003 7.3L Power Stroke Diesel 22 11-21-2013 07:58 PM
Need Turbo Rebuild Help RIJID-FORD 1999 - 2003 7.3L Power Stroke Diesel 14 10-05-2012 08:09 PM
Ported compressor housing or 1.0 A/R exhaust housing? Robert6401 1999 - 2003 7.3L Power Stroke Diesel 11 01-31-2012 11:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
