Champion Radiators? - Ford Truck Enthusiasts Forums
Champion Radiators?
Old 04-18-2014, 03:58 PM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
Champion Radiators?
does anybody have any experience with this brand? I'm looking at an all-aluminum, radiator for around 275 shipped. It even has the toppings for a tranny cooler line, I just have to transfer them from my old radiator or put in new ones. Its also a 4 core.
Anybody know of their quality?
Old 04-18-2014, 04:09 PM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
I was looking at an all aluminum radiator and I think I went with the aluminum radiator that has the plastic sides for the trans cooler. I didn't see it as being worth it. Really that's all you get in an all-aluminum rad...are the sides are aluminum instead of plastic. It might help to cool the trans fluid a little more but I doubt it. If you are worried about the trans fluid temp, I'd suggest an after market trans cooler you can put in front of the rad for more cooling power.
Old 04-18-2014, 04:24 PM
Quote:
The thing is, the spot you see a radiator fail a lot is the seam between the tanks and the middle section of the radiator. Also I've never seen a 4 core direct fit plastic/aluminum radiator before.
Do you know of any?
Old 04-18-2014, 04:28 PM
RIKIL's Avatar
I had the problem you are describing. The rad I had on before the one I have now I think I had for ~10 years. No on the 4-core.
Old 04-18-2014, 04:32 PM
That's the reason why I was looking at the Champion. A 4-Core all aluminum radiator with trans-cooler fittings and original mount locations.
Old 04-18-2014, 04:35 PM
RIKIL's Avatar
I have not had a problem with any type of corrosion or rusting of the rad and, now that I think of it, I wonder if it's because I use 100% coolant - no water.
Old 04-18-2014, 04:42 PM
Or if you do routine maintenance and flushes that could be it. Also, most morons use hose water and not distilled. But ethylene glycol (the chemical in antifreeze), is a **** poor conductor of heat. So thats why water is used in the mix. The boiling point is higher when its mixed with water.
Old 04-18-2014, 04:44 PM
RIKIL's Avatar
Quote:
I have not typically flushed the radiator for maintenance, but I have done it every once in a while. Just not on a regular basis.
When I had the stock fan on the motor I never had a problem with heat (I have a digital water temp gauge).
Old 04-18-2014, 04:46 PM
What fan do you have now?
Old 04-18-2014, 04:59 PM
RIKIL's Avatar
It's one of these - http://www.summitracing.com/parts/der-16842/overview/
That might not be the exact size but that's the brand. It's dual fan, 4000 CFM.
Old 04-18-2014, 05:09 PM
How much modifying did that take to bolt up?
Old 04-18-2014, 05:16 PM
RIKIL's Avatar
No modifying. It comes with the necessary brackets and such to install it as a universal replacement. However, to make things more convenient, I did have my friend weld the brackets to the fan housing. I had originally installed it with the supplied bolts as I mentioned but found a more convenient way of permanently mounting the brackets, so I called him.
Note these pull 24 amps, and I think that's for each fan. So you'll need to get a new alternator. If you do go this route, I'd suggest converting to a 3G and getting one that has more amps than you need, just for extra room. I upgraded the stock 95 amp to a 160 amp 3G and had a 175 amp fuse between that and the battery. Upon inspection one day I noticed the fuse was twisted and the housing melted as if someone played football with it...so I was at capacity. I have since upgraded and no longer have that issue.
Old 04-18-2014, 05:19 PM
Curious how many CFMs a mechanical fan pulls vs these ones. The Perma-Cool setups pull 5900,,I think yours is in the 4k range, still good, but curious what stock is.
Old 04-18-2014, 05:22 PM
The 3g alternator is on my list of upgrades to do. Probably buy from RJM tech and also get the headlight harness, and run LED lights everywhere but the headlights. That along with a more powerful alternator and unless my battery goes dead, I won't run out of power.
Old 04-18-2014, 05:23 PM
RIKIL's Avatar
With the aluminum rad I have, many times in the winter the fans don't even turn on (the PMC turns them on at 180F). In the summer with the fans on, I don't think I have seen the water temp above 200F unless I sit at a signal on the hot asphalt for an extended period of time. I am happy with this setup.
transmission leak at radiator justcruzin125 1987 - 1996 F150 & Larger F-Series Trucks 1 07-06-2015 10:24 PM
2011 - on Gas Super Duty Radiator Thickness Question troverman 1999 to 2016 Super Duty 2 06-03-2015 03:04 PM
Radiator Flush Product? happscrap 6.0L Power Stroke Diesel 11 11-22-2014 05:04 PM
radiator crack 20k miles antwan181 6.7L Power Stroke Diesel 10 09-30-2014 03:50 PM
what type of radiator Desarata 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-10-2013 05:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
