Engine identification? - Ford Truck Enthusiasts Forums
Old 04-18-2014, 02:50 PM
ryceman168 ryceman168 is offline
ryceman168 is starting off with a positive reputation.
I am wondering what engines I have recently acquired. They were in the back of an old shed for years. The tag on one says: 429 69 4
9-D K815-U.
and the other says: 429 70 6
9-K K815-A.
Any help would be greatly appreciated!
Old 04-21-2014, 01:10 PM
-mywheels- -mywheels- is offline
-mywheels- is starting off with a positive reputation.
Are there any numbers by the starter? If so, post those.
Old 04-25-2014, 10:55 PM
There are numbers on the back of the block that read: 9Z604674.
Old 04-26-2014, 12:37 AM
Numbers on the side by the starter are the ones I'm talking about.
Old 04-26-2014, 04:37 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
The tag on one says: 429 69 4 9-D K 815 U / and the other says: 429 70 6 9- KK 815 A.
Engine ID tags: K 815 U & KK 815 A = 1973 429 4V
Old 05-17-2014, 11:44 AM
The numbers by the starter are C9VE-B.
Old 05-17-2014, 02:01 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
C -1960s
9 - 1969
V - Lincoln
E - Engine.
A 1969 Lincoln casting revision, with the B maybe being another revision. No surprise in a 1973 motor.
Deck height would be a question, as it appears there were several revisions, this possibly being the last for C9.. blocks. See the notes on deck height etc here:
Kelly hotrod - Ford Engines Page 2
Probably just a run of the mill pillow barge smog motor. Perfect for a minor rebuild into a 700 horse mountain motor. Get to work!
Old 05-17-2014, 03:18 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Quote:
Originally Posted by 85e150six4mtod View Post
C -1960s
9 - 1969
V - Lincoln
E - Engine.
Actually some numbers aren't adding up. A C9VE block would be a huge surprise on a 73 motor. It should have a D1VE block.
And you can't use casting revision numbers to determine where it came from. Just because it has the V for Lincoln does NOT mean it was ever in a Lincoln but rather that the ORIGINAL use of that engine group was for a Lincoln
BUT the ACTUAL decoding on that engine tag indicates it's a 69 429-4V.
Old 05-17-2014, 05:21 PM
From the above tag decode:
OP needs to tear them down and inspect if he's going to use them anyway. He'll figure it out.
Old 05-17-2014, 11:38 PM
The motor I am referring to is a 1969 Ford 429. Not a 1973. At least that's what the tag attached to it says. I was told it could have been out of a T Bird but that may not be true.
Old 05-18-2014, 12:49 AM
[QUOTE=ryceman168;14273744]
429. 69 4
9-D K815-U.
429 70 6
9-K K815-A
OK, if I read this correctly, you have a '69 made in April of '69 and a '70 made in October of '69.
I.D. Tag Information -- The Ford V-8 Engine Workshop
AFAIK those would have been 11:1 compression engines, T bird, Galaxie or Mercury land yachts.
Does it have a 4bbl intake and the words "Thunder Jet" on it anywhere?
The Lincoln connection would be that the 429 and 460 blocks are the same, with Lincoln using the 460 at that time.
As I said earlier, since they have been sitting and since you don't know the condition, a tear down would be a good idea. Also, they probably do not have hardened valve seats unless someone did that later, and with 11:1 compression, they will be hard to please gas wise.
Old 05-18-2014, 09:45 PM
It has a 2 barrel manifold on it. No thunderjet anywhere.
Old 05-18-2014, 11:41 PM
There were Mercury 2bbl 429s, not sure if they found their way into Fords. The Marquis had one as the standard engine. Supposedly the same specs and a "Premium Fuel" engine with the same compression as the 4bbl.
The insurance man would relax if you had a 2bbl, but panic with a 4bbl.
Also, I see 11.3:1 compression referenced for the "Thunder Jet" motor, a figure I recall hearing years ago when these motors were new.
Serving suggestion for that concours restoration you might consider:
1969 Mercury Marauder Monterey Marquis 429 2V Air Cleaner Top Lid Decal Sticker | eBay
5.8 Postmortem Scndsin Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 07-13-2016 09:59 AM
My New Ride #prouddaddy Truck815 1994.5 - 1997 7.3L Power Stroke Diesel 20 02-09-2016 07:03 AM
What grade gas for a 429 maytea 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-19-2015 10:27 PM
88 F-700 dump truck 429 gas, what oil to use? RockinTK Large Truck 7 05-13-2010 09:54 PM
Help decoding 429 engine ID tag dani9678 1967 - 1972 F-100 & Larger F-Series Trucks 4 03-15-2010 03:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
