Where to begin 65 f100
im about to pick up on a project my dad started and never finished 10 years ago. it was my first truck and he was fixin it while I was in Iraq I had plans to fix it but thanks to a thieving mom I had no money and had to go straight back to work. so I need some ideas for the gas tank since I don't have one behind the seat any more and also where is a good place to get a new wiring harness. damn rats got mine and I want it to be done right. any ideas or suggestions would be great. oh and does anyone know where I can git the door skins
As for the gas tank, you can do a search and find some options but the most common is putting the 66-70-ish Mustang gas tank between the rear frame rails. I did that to mine and it works well.
If you're going aftermarket on the wiring harness, it all depends on how much money you wanna spend. EZ wire, Painless and various others make affordable harnesses that can be adapted. I'm no wiring expert but several on here are.
On door skins, I wouldn't bother. I'd just look for a better pair of doors. There should be quite a few around that are more affordable than skins and save you all that labor.
Hope that helps a little....
pipeliner83
04-22-2014 11:27 AM
