Edelbrock carb not returning to idle? - Ford Truck Enthusiasts Forums
Old 04-18-2014, 11:38 AM
bigdan1979f-250's Avatar
bigdan1979f-250 bigdan1979f-250 is offline
bigdan1979f-250 is starting off with a positive reputation.
Have a 600 com Edelbrock 1405 carb I am having some issues with. Any time I gradually bring up the rpms and then take my foot off of the gas pedal, it stays at whatever rpm it was at before taking my foot off the gas. I can then tap the gas pedal and the motor returns to idle. It is manual choke(which I have disabled and wired the linkage to keep the butterfly open). My question is what would cause this to happen, something internal? The only other thing I can think is that my return spring(spring that pulls the throttle against the idle adjusting screw when you take your foot off the gas) is not strong enough. Any ideas?
Old 04-20-2014, 10:48 AM
hotstuff hotstuff is offline
hotstuff is starting off with a positive reputation.
incorrect alignment of throttle cable , on the pass side there is a clearance of .040 on the throttle shaft tang , my last idea would be slop in the throttle shaft . Good luck
Old 04-29-2014, 02:48 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Could be a weak spring or the throttle plates could be hanging on some kind of build-up on the throttlebody plate. it could also be what hotstuff said above.
Old 05-15-2014, 06:54 PM
Thanks guys, putting on a stronger idle return spring fixed it.
No Acceleration captanron 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-18-2016 12:46 AM
65 F100 Throttle/Pedal Sticky jlintvet 1961 - 1966 F-100 & Larger F-Series Trucks 7 12-28-2015 08:37 PM
cold idle speed fordguy98 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-26-2015 11:22 PM
04 Expy - Idles at 15-18 mph sometimes.... Fat Slob 1997-2006 Expedition & Navigator 10 01-31-2014 06:20 PM
Help me gas pedal sticking BIG-COUNTRY 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 11-25-2005 11:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
