90wt smell - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
90wt smell
Old 04-25-2014, 11:32 AM
sv250's Avatar
sv250 sv250 is offline
sv250 is starting off with a positive reputation.
Ok checked the vent tube and frame rail. Its all dry, but i will take your advice and not use 4x4 as awd. Thats what i was worried about. Maybe it got just hot enough for fumes or a little in the tube that didnt come out.
Ill still redo the ccv mod as well. I havent had the smell in a week now. Good advice from all though thanks.
Intro wirelessmike 1961 - 1966 F-100 & Larger F-Series Trucks 1 06-30-2015 01:29 PM
front axle blowing out 90wt elkarcher1716 1973 - 1979 F-100 & Larger F-Series Trucks 32 04-26-2014 03:19 PM
Dana 44-6CF-HD roadtoad New Member Introductions 1 06-08-2006 09:29 PM
Transmission/Transfer Case Oil to Use? Monte Doenz 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-05-2005 04:11 PM
gross wt. of 1942 3/4 T PU Howard Fish 1947 and Older Ford Trucks 8 08-18-2004 01:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
