2nd Gen Compressor Wheel (don't know what to think)
#31
Richard and Rich Yep as soon as i posted i looked it up and thats what i found too !!! WHEEEEW so any info on adding the resistor ? A write up or how to parts etc ? and could this be done with the p0475 code too ?
I feel as were off topic discussing boost and codes etc lol !!!!! I'm not worried though.
KEN.... I too am running 4" turbo back straight piped exhaust but with a 6" tip. The 6637 seems to me like it would be louder since the filter just sits in the engine bay. Mine is in a sealed box but draws air from the fender well and the grill where the zoodad mod is located similar to stk.
When you say you got yours up in the 20's yesterday on your run describe a run. Is that WOT ? or just a really heavy foot.
As far as the noise its not bad the higher the bst level. It seems to be the loudest between 2 and 4 psi. If you want to know what noise I'm referring to try this ...........
Go out and close the passenger side air vent to the right of the air bag by the window completely. Open the other 3 vents and turn the A/C to MAX A/C and turn the fan all the way up. The whistling noise from the closed vent in the cab sounds very very similar to what my new wheel sounds like now around 2 to 4 psi.
Reason i know this is my wife always closes that vent and when i get in and fire up the a/c on a hot day that noise drives me nuts and i just can't lean over and open the vent LOL but thats the best i can describe the sound.
#32
#33
Ok! I am sitting in my truck and just did your test. I am not helping very much, cause mine did not whistle, it just sounds like air blowing! Heck, maybe my hearing is going! I have driven my truck a lot with the new wheel and it is not annoying at all. I have driven over the pass and held it at all different boost levels. Mine is loudest when I am about 15psi and up, that is why I thought it might be loud when towing over the pass. Does yours bother you when you are towing or even when empty just cruising? I have never posted a video, not even quite sure how to! If I get in touch with Woodnthings next week I will see if he will post a video! I usually do my boost runs on a hill by my house, not wide open throttle, just a heavy foot usually. I start at the bottom at about 30mph and roll into it until I have to shift or get close to 3k rpm and let off.
#34
Is your noise loud under the hood, like at the turbo or out the exhaust?
I took some quick phone videos for comparison's sake if nothing else.
Apologies for the first video's radio, I didn't realize it was that loud but I guess the mic picked it up well.
<iframe width="420" height="315" src="//www.youtube.com/embed/ewzeIPw9hUY" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="//www.youtube.com/embed/8651-n_iufs" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="//www.youtube.com/embed/cToaXl1RGV8" frameborder="0" allowfullscreen></iframe>
#35
My tests normally are comparable to yours. Not WOT as i can't push my self to do that but its normally a really heavy foot. Now i feel the turbo is fully broke in from the rebuild I've gotten back to a more normal style driving and it appears I'm about the same as boost levels go. I like you have no idea how to post pics more less a video and would love to learn how lol
#36
#37
Mine is no where near as loud as the Early wheel aka "WW". It does have it's own tone, and lower pitched, but compared to spinning the early wheel vs the 6/6 in the upper 20's low 30's boost levels there is no "ear-piercing" level. But everyone deals with frequencies and pitches differently too.
#38
dfuser.#P0541 code eliminator
dfuser.com #EBVT code eliminator
or you can do it yourself with some resistors from radio shack for a few bucks $....
Here are links to a AIH & EBPV code eliminator threads......
https://www.ford-trucks.com/forums/1...-delete-2.html
https://www.ford-trucks.com/forums/1...-solenoid.html
#39
#40
#41
I've read a few posts saying the Bellowed up-pipes have an effect on the exhaust sound. Nothing big but a change that might need some getting used too. Maybe you have a couple things contributing to the mix? I have the new wheel and did the UPs at the same time too. But it was right after getting the truck and I never really drove it before the work. I've put 800 miles since getting it back on the road. I really can't hear anything from the turbo till its really under a load. ..new gauges still setting on the bench. I still have the stock air box and filter, not sure if that has much effect. I plan to pick up the Ford AIS in hopes its not much louder than stock.
#43
The Ford AIS isn't any louder than stock - unless you drill the 3" hole in the side to allow for more air after adding a chip or injector upgrades, and even after that it isn't much of a difference at all. I really like the AIS. I still switch back & forth between that and the 6637 on my F-250.
#44
Anthony Giovino
Ford Truck Parts for Sale
04-15-2017 07:50 AM
diehardstroker
59
04-10-2017 05:48 PM
