2nd Gen Compressor Wheel (don't know what to think) - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-17-2014, 11:11 PM
bakerbuilttracks's Avatar
bakerbuilttracks bakerbuilttracks is offline
bakerbuilttracks is starting off with a positive reputation.
Rich look above your first post and read through there one more time LOL !!!!! S&B with Dry Flow Filter
Old 04-17-2014, 11:12 PM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Bakerbuilttracks, Right now your setup is reading the same boost that the PCM sees from the manifold called manifold gauge pressure. A boost fooler will tap into the line going to the MAP sensor and will make the PCM see 22 psi max to prevent the defueling even if true boost is above that. Without a boost fooler you will max out around 22 psi. Which isn't a bad thing since the stock turbo doesn't handle well over 27 in the long term.
Those that install a boost gauge will see the true boost instead of what the PCM is seeing.
Yep, it can be frustrating when folks talk about stock when the only thing stock is the tune called stock that might be a bit different from your original truck's PCM stock!
Old 04-17-2014, 11:13 PM
Quote:
Ooooopppps!!!!!!
Thanks!
Old 04-17-2014, 11:36 PM
Yep, it can be gust rating when folks talk about stock when the only thing stock is the tune called stock that might be a bit different from your original truck's PCM stock!
So i understand installing the boost fooler and how it works. But if I'm throwing 25 actual psi why is the MAP not picking that up i guess is my question. For example ..... If the PCM's max for the turbo is lets say 20psi. When it gets close like 15 or 16 it slowly defuels allowing it not to reach 20. Or dose it let it climb to 20 then defuel like a blow off valve.
If it starts defueling before it can even reach 20 then i see why I'm seeing the #s i am. But if its the other way then i should be seeing 20. If that makes sense LOL
Old 04-18-2014, 12:23 AM
Here's a link to a good video clip and some turbo info. Basically a wastegated turbo is going to start opening depending on the actuator spring & actuator diaphragm. Since you have a BD wastegate installed with 5 additional turns and the red line disconnected you can't compare it to stock.
IIRC the wastegate on a stock setup will open much earlier than 20 psi to prevent overboost.......but then PCM will take over and start to defuel if the boost (MAP minus Baro) goes over 22 psi.
7.3 Waste gate adjustment - YouTube
check out these PDF documents Robin posted.
http://www.ford-trucks.com/forums/11...operation.html
edit: since you have the BD wastegate - reconnect the red line and reset the actuator to the original settings then adjust it from there. Your gonna have to go more than 3/4 throttle to see max boost, but keep in mind that without a boost fooler your max will be @ 22 psi.
Old 04-18-2014, 12:38 AM
........... But if I'm throwing 25 actual psi why is the MAP not picking that up i guess is my question................
Your not going to make 25 psi right now. Not without a boost fooler. If I understand your questions correctly, please correct me if I'm wrong.
1. the wastegate is controlled by a mechanical spring & diaphragm. The spring is set to a specific tension that must be overcome in order to open the wastegate. The red line will help overcome the spring tension when the boost gets too high.
2. If these two items cannot keep the turbo safe from the overboost condition then the PCM takes over at 22 psi and defuels.
........... For example ..... If the PCM's max for the turbo is lets say 20psi. When it gets close like 15 or 16 it slowly defuels allowing it not to reach 20. Or dose it let it climb to 20 then defuel like a blow off valve. ...............
The stock wastegate starts to blow off before 20, you can see that in the video clip posted above. But the wastegate does not control defueling, that's the PCM's responsibility and that starts around 22 psi. That is why the boost fooler tells the PCM the boost is at 22 psi whenever the boost is 22 psi or higher, to keep it from defueling and setting the overboost code & check engine light - thus allowing the chip/tune to keep adding more HP.
Did I confuse things more?
Old 04-18-2014, 12:48 AM
In addition, compare your S&B intake to what intake Boss73 is using. Your open air element will let the sound through a lot more than a setup like the AIS. But in his last post he said he only went up to 6-8 lbs of boost - I don't think he hit the noise levels the others have posted.
Bottom line - if you (or anyone else) likes the performance of the Gen2 WW but can't stand the noise then change your air intake. The Ford AIS with the fender sleeve is one that comes to mind. But if your running bigger injectors or higher HP you might not have much of a choice.
Old 04-18-2014, 05:57 AM
River19's Avatar
River19 River19 is offline
River19 has a good reputation on FTE.River19 has a good reputation on FTE.
A quick and easy "boost fooler" is the Riffraff OCR....<$100 and takes 10mins to install, just sayin.
I have a dedicated boost gauge as well as a Scan gauge and the mechanical boost gauge with stock turbo and OCR will hit 25-27ish psi at WOT without defueling now. And I was defueling quite obviously prior to the OCR.
BTW, what does disconnecting the red line do? Not that I was planning on it, heck I'm pleased as punch I have the boost I do at this point....but just for my own education.
Thanks
Old 04-18-2014, 08:39 AM
Borrowed from one of Muekster's Posts....
Plugging the red line from the WG solenoid to the WG actuator will net higher boost.
Here is the link for mor info with a great diagram from the service manual on how the system works:
http://www.ford-trucks.com/forums/11...take-tube.html
To update some of the numbers I posted previously:
1. The PCM will start defueling at 23 psi
2. The stock WG actuator starts bleeding off boost at ~ 5psi.
Old 04-18-2014, 08:41 AM
Quote:
OCR - Overboost Code Regulator - Riffraff Diesel Performance
Old 04-18-2014, 08:59 AM
River19's Avatar
Thanks I was lazy earlier this morning
Awake now......well more awake....
Old 04-18-2014, 10:06 AM
Rich thanks for all your help and advice on this !!!!
I had to run the dog to the vet this morning for shots and was able to do some more tests.
On stock it seems like I'm close to normal psi as i was before. I stuck it in 80e and got on it fairly hard (its pouring rain here in the south ) and hit about 17ish.
On the way back in stock i took off normal and as it hit 3rd gear i went to the floor with the pedal and hit 21lb. So i think I'm good !!!!
Im not concerned with how much boost i make as i NEVER stick the skinny to the floor. Im just wanting to make sure everything is normal.
Now i did check my codes and i keep getting 2 popping up ! the first is p0475 which is EBPV malfunction which was my fault. Pulling the turbo out it slipped and hit the plug and broke it off the sensor Yea good move huh.
The next is p0541 and i have looked in my book from edge with all the ford codes and there descriptions and have found no description for this !
  #28
Old 04-18-2014, 10:26 AM
Boss73's Avatar
Boss73 Boss73 is offline
Boss73 is starting off with a positive reputation.
Sorry guys! I'm at work and just popped on to check this thread. I am running a 6637 intake and I did take the boost up in to the 20's on my run yesterday. It just doesn't seem that loud to me. If I have the chance, I would give someone else a ride and see what they think. Like I said, I won't be towing over the pass until next month, but I will post up anything I think will help for comparisons. Not sure if having a 6 speed manual makes any difference in sound or not! I will try to get in touch with Woodnthings next week and see if we can hook up and take a spin.
Also I am running straight 4", no muffler and a 5" tip.
  #29
Old 04-18-2014, 10:30 AM
P0541 Manf Intake Air Heater Circuit Low
the 0541 code is from the AIH delete you did, you can add a resistor into the circuit to remove the soft code.
Here is the link to guzzles page, scroll down and you can click on the "index of diagnostic trouble codes" to view the DTC's.
Guzzles DiagnosticTrouble Code List
  #30
Old 04-18-2014, 10:35 AM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
p0541 Air intake heater, Have you deleted yours?
http://www.ford-trucks.com/forums/10...ode-p0541.html
Holding her breath...any tips? ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 82 10-11-2016 09:50 AM
Decision made on Injectors exbxtoy 1999 - 2003 7.3L Power Stroke Diesel 46 09-13-2016 02:25 PM
Billet compressor wheel and quick spool on stock sticks Ezalycasaid 1994.5 - 1997 7.3L Power Stroke Diesel 31 03-29-2016 10:53 AM
Order of mods SSSimon Australia Chapter 5 12-28-2015 02:15 AM
Installing more efficient wheel, ebpv, wastegate, etc question Sous 1999 - 2003 7.3L Power Stroke Diesel 16 03-09-2015 08:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
