howling in front end
Does not make difference when applying brakes.Sound starts at about 25mph and stays there going up in speed and stops when you stop.But you get no sound from right side just left side.I have had my blazer bearings go bad and does not sound lake that.Could it be cv joint or just replace right side.Thanks
Generally a worn outer CV joint would make noise when turning and a worn inner CV joint will make noise on brisk acceleration. A worn CV joint generally will not make noise just cruising down the road. As far as you're aware, has this truck ever had a damaged CV boot on the left side of the truck that was repaired rather than a remanufactured halfshaft being installed?
Without being able to hear the sound, I'd still be leaning towards wheel bearing, but if you have a local acquaintance that is pretty experienced with car repair, you may want to have them go for a ride and give their opinion.
Have you checked the front suspension for any looseness? What year is this truck/does it have independent rear suspension?
-Rod
-Rod
resq302
08-21-2018 10:29 AM
radck
10-30-2016 04:01 PM
SuperDutyScaler
1999 to 2016 Super Duty
46
09-09-2015 05:08 PM
natew
07-12-2015 08:48 AM
kuboy
2004 - 2008 F150
10-15-2012 05:09 AM
