CREWCAB ONLY
#271
#273
#274
Seems like this thread took a different from the way it started.... Here's mine! I like it cuz it's easy to turn around it crowded parking lots.
89
7.3 idi
ZF5 manual swap
4 in lift by Superlift
Interior from a 91 so it's a nice brown instead of VERY RED EVERYTHING
Hidable 5th wheel hitch
Wheels that are wide enough for bigger tires. I've getting 285/75s once these wear out
#275
My first one was $1 with 500,000 miles.Family cared for rollaway truck with sliding rear window. 2wd 7.3 c6 Great truck, dead reliable.
Second one was a 95 dually with a PSD E4od. Powerful truck but would have random electrical issues, Shift module in the speedometer, injector harness, Nothing bid but parts were a little more pricey and $100 oil changes, 6 tires, Truck was costly to operate.
Third truck I bartered some work for. 97 xlt 120k on a 460 E4od MAF truck. Great truck, gas hog but reliable, I replace 3 steering columns, (don't pull yourself into the cab with the wheel) and a water pump/radiator combo at 180k, sold it to move back to Vegas
Now this is my F off truck, No emissions, 460, 5 speed Long tube headers into super 40s rough ride and loud as hell. I work at Shelby and set off car alarms leaving the lot. Just a daily to work and back as the hot rod plates only allow 5000 miles a year. This is my toy.
#277
If you want to change the interrior... I just did that to mine. I had to find a donnor truck. If you can't find the complete interior, a full size Bronco of a similar year should have a dash that will fit.
#279
You can die/paint yours. You can also use the Bronco front seats and consol. I'm going to be doing that with mine. I don't mind the bench seat, but I'd like to have somewhere to set my coffee cup and stash stuff. (I did a manual tranny swap so there is no room there).
Like I said, the best option is to find a donor. If you paint/die your parts then it can wear off, so that's why I would suggest that you at least find a dash. The carpet can be replaced for less then 200. The headliner can be died/painted. They sell those kinds of products in spray cans at auto stores.
#281
Thank you, I'm up in washington and haven't been able to find many donors but ill keep looking
#283
next dying the interior parts does NOT last for color changes. The dash is the LEAST of your concerns. The door panels are a HIGH wear item and the drivers door panel is crew cab specific
