What causes low oil pressure? - Ford Truck Enthusiasts Forums
Old 04-16-2014, 07:57 PM
Number21 Number21 is offline
Number21 is gaining momentum as a positive member of FTE.
Been having a long/confusing list of issues with my 04 F350. Seemed like a problem with the HPOP not making enough pressure, having hard starts, low power, and finally no start. Finally took it to a mechanic and he sounds like he knows what he's talking about, but he's still kind of confused by my engine.
The mechanic put a mechanical oil pressure gauge and says he's only getting 2psi cranking. He can get it to idle sometimes and the pressure is 6psi. I'm surprised it can even run with that low of pressure.
Right now the mechanic wants to take off the cover for the low pressure pump, he thinks maybe there could be some scaring in there causing a pressure loss. I changed the oil about 25 miles ago, and I found some fine metal particles on the magnetic drain plug. The oil filter looked clean.
The biggest issue is why, even if the low pressure pump is bad/scarred, what caused it? Any common causes of these symptoms? Where did this metal come from? He also says the IPR is acting funny, but it's hard to test because the engine will barely idle and not rev at all.
Old 04-16-2014, 08:51 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
I believe a few folks have found a big hpop side leak can starve the lpop. Hopefully someone can give you some help to narrow it down.
Sent from my Sprint PC36100 using IB AutoGroup
Old 04-16-2014, 08:55 PM
Lx460 Lx460 is offline
Lx460 is gaining momentum as a positive member of FTE.
On the front cover there is a screw in tube with a check ball and spring. Accessible from under the truck. If it gets gummed up or stuck you'll have no oil pressure. Free to check and see before you go digging further. I've had a couple trucks with this issue. If not your oil pump (gerotor) is probably worn. Depending on wear, front cover may need replacement as well. How many miles on truck?
Old 04-17-2014, 01:16 AM
Quote:
That's exactly what my mechanic said. But the question is why? Do they just wear out? I've got about 198k on it.
Is it ever normal to find a little bit of fine metal on the magnetic oil drain plug? My mechanic thinks maybe this metal came from something else and ruined the pump on its way out.
Old 04-18-2014, 11:45 AM
Asheville Engine's Avatar
Asheville Engine Asheville Engine is offline
SPONSOR
Asheville Engine is gaining momentum as a positive member of FTE.Asheville Engine is gaining momentum as a positive member of FTE.
If you had metal particles stuck to your MAGNETIC drain plug it's because something STEEL is coming apart in your engine.
There are several likely causes, HPOP could be one, lifter failure could be another. If your mechanic finds needle bearings or impressions of them in your georotor gears, you have a real problem...but I can help with that.
__________________
C:\Users\Debra Newcomb\Pictures\bg-1-339546.gif
Old 04-23-2014, 08:10 PM
My mechanic finally got the low pressure cover off, and says it is pretty badly scored. Waiting on a new one from Ford. He thinks that's why there is no oil pressure, but still not sure what caused that.
Also he thinks there might be something clogging up the IPR valve, possibly the same metal that went through my pump. Any ideas where this metal came from?
Old 04-23-2014, 08:15 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Can you post photos of the old gears? A common cause of LPOP damage is a failed lifter sending needle bearing pieces to the oil pan and ultimately through the LPOP and it leaves very distinct markings on the LPOP gears.
Old 04-23-2014, 08:22 PM
Quote:
I don't have a pic but he said my pump looked like it was in good shape, he wasn't going to change it. Only the cover was scarred. He specifically said he's seen lifters do that before and it doesn't look like that happened.
Old 04-23-2014, 08:28 PM
Misky6.0's Avatar
I wouldn't put a new pump in until your make sure you find the source and verify there isn't any more metal pieces... You don't want to do this again, do you?
Old 04-23-2014, 09:45 PM
captfatboyf250's Avatar
captfatboyf250 captfatboyf250 is offline
captfatboyf250 is gaining momentum as a positive member of FTE.captfatboyf250 is gaining momentum as a positive member of FTE.
Wrong board my bad
Old 04-24-2014, 11:33 AM
SPONSOR
Ditto what Misky6.0 said.
Figure out what is coming apart before you have to buy a new engine.
__________________
Old 05-06-2014, 03:56 PM
Well, my mechanic is still digging into my engine...
He replaced the low pressure pump, and says now the oil pressure is where it should be. Still doesn't run right.
He rebuilt the IPR - says there was a lot of metal in the screen.
Still won't do much more than idle. Today he's checking the high pressure system and probably the pump.
Before I bought the truck, I was told the HPOP had already been replaced not that long ago. It is a late model 2004(June), with the ICP sensor on the valve cover, but my mechanic says it might have the old style HPOP. Is this possible? As I understand it, the later HPOPs almost never go out...
He seems to think maybe something blew up in my engine in the past, never got cleaned out, and it just now found it's way through my pumps. Been finding a lot of evidence of a prior bad mechanic.
Old 05-06-2014, 04:29 PM
Your truck would have the old style pump. It was in 05' MY the new pump was introduced and the source of the metal on the IPR screen is probably from the pump internals.
Old 05-06-2014, 04:32 PM
Then why do most of the pumps I've looked at say 2003-2004 or 2004.5-2010? I've never seen 05 as the different year...
Example:
Old 05-06-2014, 04:40 PM
I cant tell you why, the 2003-2004 makes sense but the 2004.5-2010 makes no sense. Look through this 2005 coffee table book from the tech folder, http://www.ford-trucks.com/ford-manu...ble%20Book.pdf
5.4L 3V - Oil Pressure at Idle JRROTH1 Modular V8 (4.6L, 5.4L) 13 01-05-2016 03:36 PM
Oil Pressure issues--4.0 SOHC rebuild IronHorseDriver Ranger & B-Series 4 10-02-2015 01:01 AM
Lpop pressure issue... 2000ca250 1999 - 2003 7.3L Power Stroke Diesel 12 03-09-2014 01:49 PM
'02 4.6L "Low Oil Pressure" quick35th Explorer, Sport Trac, Mountaineer & Aviator 6 05-09-2013 10:04 AM
302 low oil pressure - in Explorer 2001 EB SoNic67 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 23 11-17-2010 04:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
