installed Soffseal door seals today - not good - any tips??
1951 Ford, F1. Seals seem like a quality product and fit well. But....
The door is incredibly hard to close!! And the strikers are adjusted all of the way out.
I installed the portion between the lower 2/3rds of the door and the A-pillar, first (they come in 2 sections.) That seal caused most of the interference. The other being the top 1/3 of the a-pillar, over the top of the door and down to the bottom rear corner. Maybe it is just the portions being pinched between the hinge halves?
Anyone think they'll loosen up after being squeezed for a while?
I'm disappointed. I will call Soffseal tomorrow. Their website says 100% satisfaction. At this stage, I might as well have welded the door shut.
I have only used their products on the woodies that I built or worked on. All wooden doors that I built so I was able to leave enough room for the weather strip and using their universal product so there is really no way to judge. I never had any complaints with it though. I was planning on using their seals on my '52 so please let me know what they tell you when you talk to them.
Door seals are usually too thick. I buy some universal stuff in 50 lengths and use it rather than fighting and slamming doors all the time. And a poorly adjusted or not working latch/strike plate will trick you into thinking seals are too thick also. So check it all out.
I heard this from mid-fifties. Also, I will call Soffseal later today. I read on a tri-five board that many use a heat gun to allow the seals to deform and that it is common for soffseal seals to be too large.
Hi Doug,
We do have hollow door weather stripping, but it already has molded corners specifically for 1953-55 & 1956 doors. You may be able to make them work, but I am unfamiliar with F1 doors, so don't want to point you in the wrong direction. You should give Classic Haulers a call as they specialize in just 1948-52 F1's and may have more insight to your situation. You can reach them at 877-252-1948 or visit classic-haulers.com.
We also carry hollow domed weather stripping, that is not preformed. See our part number 3106-DM. I have attached a picture of a cross section for reference.
Please let me know if you have any questions.
Thank you,
Jesse
Mid Fifty F-100 Parts
Hi Doug,
Thank you,
Jesse
Door seals
I used the hollow seals from Mid Fifty, and they allowed the door to close easily. However they didn't seal quite as well as I wanted (wind noise) so I glued a then flat softseal to the cab door opening so the two seals come together when closed. It stiffened the door closing a bit, but not excessively so, and it quelled the wind noise.
A few months later, I'm real disappointed with the seals. The rubber quality seems great, but I have to slam the CR@P out of the door to try to make them close all of the way. The seals are just very dense. I tried setting the truck in the sun, using the heat gun, etc. I might have been able to make them fit 5% better. Barely perceptible improvement.
I talked to the folks today at Steele rubber who are sending me a sample kit of their half round hollow seals. Likely, I'll be cutting most of these out and replacing with something from Steele. Quite frustrating process. I plan to possible save the parts which are molded under the door hinges.
Doug
Doug
