installed Soffseal door seals today - not good - any tips?? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-01-2014, 05:58 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Sorry to hear that the Soffseal didn't work. I still haven't gotten any seals yet but I was planning on using them. Look forward to your luck with the Steele seals.
Old 07-04-2014, 12:04 PM
fbb1951's Avatar
fbb1951 fbb1951 is offline
Brent
fbb1951 has a good reputation on FTE.fbb1951 has a good reputation on FTE.fbb1951 has a good reputation on FTE.
I bought seals from LMC Truck. All of the door and window seals in one kit. The window seals were great, the door seals were too thick to allow the door to shut easily. The passenger door is close enough, but I had to grind a 1/16" off the striker/latch on the drivers door. With the striker/latch pieces adjusted all the way out, I can get both doors to latch with a firm slam. I hope in time the rubber will compress and take a set.
Always something new to deal with on this project. I've just had to remove the electric wiper conversion because the arms bind the motor and blow the fuze. Any threads on that problem?
Old 07-04-2014, 07:15 PM
Aus56's Avatar
Aus56 Aus56 is offline
Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.
When I got my 56, it came with a few bits and pieces. It had 2 door seals I had to fit. Unfortunately they were for the same door, passenger side. Fitted one up and it was great, door closes perfectly, no need to slam at all. Having read posts like this, I had heard of Midfifty hollow seal, so I bought one 2 weeks ago for my driver's door.
At first I had to slam it to shut it, but now it takes just a firm close. It will be interesting to see if it gets as good as the other door. Unfortunately the seals I got when I bought the 56 were not in a packet, so I do not know what brand they are but the one I fitted was great straight away. So someone out there makes good ones, just no one seems to know who. The Mid fifty ones seem like they will be alright, but no help to you unfortunately with your F1.
Old 07-05-2014, 08:18 AM
raerjim's Avatar
raerjim raerjim is offline
raerjim is gaining momentum as a positive member of FTE.
The hollow seals from Mid Fifty work great and are easy to install.
Old 07-05-2014, 10:24 AM
Holehawgg's Avatar
Holehawgg Holehawgg is offline
Holehawgg is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by fordf5 View Post
I just ordered the set from MACS but it will be a looooong time before I can see how they fit.
.....Roger
I also ordered a set for my 49 from Macs. They were the solid type and I am not happy with them at all. The door is held out about an 1/8 of an inch all the way around. Makes it look like the door is open. I even tried using a rachet strap to pull the door shut for 2 weeks hoping the seal would form to the door but no luck. I was looking at the soft seal set next so I will be following this thread.
A-Pillar Gauge Pods for pre-92' Ford Truck grena 1987 - 1996 F150 & Larger F-Series Trucks 6 06-27-2015 10:33 PM
How Do I Remove A-Pillar Trim? kailor Expedition & Navigator 14 01-28-2015 02:40 PM
Trick to remove A-Pillar trim? 93nighthawk Aerostar 7 07-23-2014 12:23 AM
Driver's side A-pillar grab handle Luvmy7.3Ex Excursion - King of SUVs 5 12-04-2012 04:58 PM
Wind Noise A-Pillar jaybread 6.7L Power Stroke Diesel 11 01-11-2012 09:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
