What length throttle cable?
Old 04-16-2014, 05:06 PM
trozei's Avatar
trozei
trozei is offline
Got a 300 in my '69 F100 with an Offy C and a Holley 350 2bbl. Looking to get a Lokar throttle cable for it. Their website suggests the TC-1000HT or the TC-1000U, which are 24" long throttle cables for carbureted systems. Will that be long enough or would I need to call them for a more custom length?
Old 04-16-2014, 05:23 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
Lay it out with a piece of wire or string and measure.
Old 04-16-2014, 07:58 PM
trozei's Avatar
trozei
trozei is offline
I'd prefer to not remove the one that's in there right now. I figured someone else on here would have already done this.
Old 04-17-2014, 07:14 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Hey trozei,
As a compromise to what BaronVonAutomatic suggested, why not leave yours attached and measure from the gas pedal to the firewall and then from the firewall to your current set-up. This will give you a pretty close overall measurement as a starting point.
Old 04-17-2014, 09:17 AM
trozei's Avatar
trozei
trozei is offline
I have a throttle linkage right now.
Old 04-18-2014, 06:38 PM
truckerdead's Avatar
truckerdead
truckerdead is offline
Trozei,
I used the tc-1000ht, on my 1981 f100 4.9 Clifford intake holley 390 4 barrel. Fit very nicely. I don't know how much different the truck body to engine location is between the two trucks. Don't know if that helps any, but the cable works great for my setup..
Old 04-18-2014, 07:12 PM
trozei's Avatar
trozei
trozei is offline
Originally Posted by truckerdead
Trozei,
Thanks. That's helpful. Our trucks should both require a similar length cable. How much extra slack does your cable have?
Old 04-18-2014, 08:25 PM
truckerdead
I routed the cable out through the firewall, around behind the valve cover low and up the right side of the valve cover, it's tucked away almost out of sight. It worked out really nice, enough length to route the way I wanted, and enough slack for some adjustment at the pedestal mount. I'd say about an 1" of adjustment.
Old 04-18-2014, 10:33 PM
trozei's Avatar
trozei
trozei is offline
Okay, cool. Thank you.
Old 04-25-2014, 02:00 AM
trozei's Avatar
trozei
trozei is offline
My DP-1000U arrived yesterday. I've got the carburetor, adapter, and now throttle cable. My intake manifold is on back order so I can't do anything until I get that. Thanks for your help.
Old 04-25-2014, 10:45 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is online now
Trozei,
I don't want to hijack this thread, but was curious how the Holley 390 worked out. Was it a new unit? What changes did you make? How is power and mpg?
Thx.
Old 04-25-2014, 02:12 PM
trozei's Avatar
trozei
trozei is offline
Thx.
I'm curious too. I got the 350 but I'm starting to want a 390.
Old 04-25-2014, 07:06 PM
truckerdead
F-250 restorer,
Bolted the 390 on right out of the box brand new. It fired right up, a small idle adjustment that's it. Now that the weather has warmed up a bit I had to make a slight choke adjustment. Truck runs great, has plenty of power and will get up and run. Normal driving I'm getting 18 mpg.
Old 04-25-2014, 11:37 PM
trozei's Avatar
trozei
trozei is offline
Ah, crap. Might just need to go get me a 390.
Old 04-26-2014, 12:33 AM
F-250 restorer
18 is very good. I assume that is on the freeway? I would also assume either you have an over drive trans or a rear with gears of 3.00 or higher?
Quick Reply: What length throttle cable?
