Wiper switch replacement
I am replacing the stock switch with a ON-OFF-ON toggle switch.
The old:
4 wires. Power wire that goes to the ignition switch, and 3 from the wiper motor. (Red, green, black).
The new switch:
Generic toggle....but only has connections for 3 wires. Power goes to middle connection, but which 2 wires from the wiper motor go to the ON connectors?
I checked the manual, but it wasn't much help.
The old:
The new switch:
I would think that one of the wires...usually the black is the ground. the other two should be hi and lo speeds. I just replaced the vacuum sys in mine with a electric motor out of a jeep and had to rewire it all up.
https://www.ford-trucks.com/forums/1...wiper-mod.html
Wiring match up is as follows...
On the switch....Large black......Power in and Black/white stripe..
......to washer
Blue/orange stripe......Red hi on motor
White.......Brown lo
Red......Green park feed
Black/pink.......Blue park return
On motor black to ground
HVFDFIREFIGHTER1618
06-25-2019 08:01 PM
DadOh1
03-11-2012 08:50 AM
mwilson
21
11-19-2002 12:41 PM
