3.5 EcoBoost Timing Chain Noise - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Old 04-15-2014, 06:44 PM
klasher klasher is offline
klasher is starting off with a positive reputation.
Thumbs down 3.5 EcoBoost Timing Chain Noise
Anyone else having an issue? Marble like noise at start up only. I did an internet search and it said this is a $4,000 dealership fix. I have 92,000miles on it, out of warranty and extended warranty is up. Oil changes done every 5K at dealership where it was purchased. I have an appointment for later in the week, but the YouTube video was the exact sound mine makes.
Old 04-24-2014, 02:31 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Buy a new extended warranty fast!
Also, be sure and use Motorcraft oil filters. Aftermarket filters may have inadequate anti-drainback valves causing less oil pressure at startup. The chain tensioners use oil pressure so that could be the issue.
Old 04-24-2014, 08:39 PM
Update: Dealer pulled code. It was not the timing chain it was the left side converter.
Old 04-25-2014, 01:52 AM
Converter wouldn't make the noise you described. It's possible the code was unrelated.
Old 07-02-2014, 03:43 AM
rmaratas rmaratas is offline
rmaratas is starting off with a positive reputation.
Im kinda curious about this issue... How did you verify that the noise came from the converter?
Old 07-02-2014, 05:40 AM
EBXLTF150 EBXLTF150 is offline
EBXLTF150 is starting off with a positive reputation.
Quote:
Vacuum pump under the driver's side headlight maybe? Others with 2011/2012 reported the same sound and it was a vacuum pump related to brake boost and the device is under the driver side headlight (general area).
But if they dealer replaced one of your catalytic converters and the noise is gone now...ok, maybe something was broke inside.
5.0 ticking/knocking mrford99 5.0L Coyote 6 02-19-2017 09:51 AM
5.0 Coyote Tapping/ Ticking/ Knocking bigdaddyII 2009 - 2014 F150 305 02-11-2017 12:47 PM
Transmission Noise chrs2ca 1999 to 2016 Super Duty 4 07-05-2016 01:13 PM
Washer fluid pump not working hoppy69 1999 to 2016 Super Duty 0 12-13-2015 03:52 PM
Family stranded in Salt Lake. HELP! BadgerBoy 6.4L Power Stroke Diesel 17 11-15-2011 08:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
