Fan for my 52 F5 - Ford Truck Enthusiasts Forums
Fan for my 52 F5
Old 04-15-2014, 06:02 PM
Joshua Farm Joshua Farm is offline
Joshua Farm is starting off with a positive reputation.
Fan for my 52 F5
Can anyone help me ID a fan for my 52 F5 8RT engine? I have an alternator with fan mount on water pump. I can't find which one or even something close. I'm not even sure what came stock on it. I'm pretty sure it was a four bladed fan. However, I have had no luck finding one. It looks like I might just have to do trial and error retro fitting. I can't live with the electric one that is on it now. It vibrates more than the engine.
Old 04-15-2014, 07:03 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
I don't quite understand what setup you currently have. The flathead V8 (8RT) did not have a generator or water pump mounted fan. The six cylinder had a water pump mounted fan.
The fan setup for your F-5 should look like this (with either a 4 blade or 6 blade fan):
Old 04-15-2014, 07:13 PM
My mistake oops, but lots of confusion
You are absolutely correct, sir. However, I can't find any aftermarket sources for the four bladed fan.
Old 04-15-2014, 07:29 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I would think if the electric fan vibrates it has lost a blade or balancing weight. Usually, electric fans are quiet and pretty much vibration free.
Old 04-15-2014, 07:40 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
The parts book actually calls for a 5 blade (18.5" dia) part# B7Q8600C. The parts book shows ONLY 5 blade fans for all trucks 1948-56, so I wonder if the 4 blade was supposed to be on the passenger cars.
38 Coupe, I see you changed the pic you posted, where was that one from, as it indicated the fan part # to be 8602?
Anyhow, Part #B7Q8600c
Dennis Carpenter has 2 NOS
Klimesh Motor Sales Calmar, IA 52132 has 2
Miller Obsolete Binghamton, NY has 1 $90.00
Old 04-15-2014, 08:08 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
I think maybe the V8s are all 5 blade. My I6 is a 4 blade.
Old 04-15-2014, 08:12 PM
38 coupe's Avatar
I was searching through photobucket for good picture that someone else had already made available. The earlier picture is actually a 1949 car engine, but the fans are similar. I updated it when I found a picture of a truck engine.
Here is the earlier picture:
The only 5 blade fan I have seen on a flathead was on a 53 truck motor and was definitely a one year only assembly.
Old 04-15-2014, 08:19 PM
harleymsn's Avatar
Here's what the parts book list.... I found Van Pelts list 8602 as a fan/hub combination
Old 04-15-2014, 08:21 PM
This is what I'm saying
You can do a parts number search for it all day long and not get anything close. My local parts stores are worthless. Anybody have a Part #B7Q8600c
18.5" diameter 5 blade fan for a 1952 8RT flathead V8? Used condition would be fine. I have to ditch the electric fan!
Old 04-15-2014, 09:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
So are you missing the whole assembly, including the hub and mounting bracket?
Old 04-16-2014, 12:22 AM
Just the fan
All I need is the fan. Anybody know where I can get one?
Old 04-16-2014, 12:43 AM
ALBUQ F-1's Avatar
postin' fool
What was wrong with these (below)?
Old 04-23-2014, 09:17 PM
Fan search
I called all listed sites and no one had one on the shelf. I bought the 5 blade aluminum one and pray that it will work.
Old 04-23-2014, 09:20 PM
raytasch's Avatar
Fan shroud willowbilly3 1957 - 1960 F100 & Larger F-Series Trucks 4 07-01-2016 04:53 PM
Electric vs mechanical cooling fan 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 49 02-16-2016 08:31 PM
When did they start using a fan clutch? Nathan Plemons 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-13-2010 06:26 PM
bent fan blades bawrestler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-07-2007 11:12 PM
Fan Clutches for 4.9L SilverSport Ford Inline Six, 200, 250, 4.9L / 300 3 11-14-2006 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
