Fan for my 52 F5 - Page 3 - Ford Truck Enthusiasts Forums
Fan for my 52 F5
  #31
Old 07-15-2014, 10:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Have you disassembled the hub and mount to see if anything is outright missing?
  #32
Old 07-15-2014, 11:12 AM
Joshua Farm Joshua Farm is offline
Joshua Farm is starting off with a positive reputation.
It appears that part 8603, the pulley, just slides back and forth and wobbles around on the shaft.
  #33
Old 07-15-2014, 11:20 AM
  #34
Old 07-15-2014, 11:42 AM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Quote:
If it slides back and forth, either the hub assembly is not bolted together properly or the spindle bearing is bad.
As you can see in this illustration, the fan bolt goes through the blade, the hub cover, the spindle bearing and the hub. The bolts are secured by the 4 fan bolt retainers.
If it is bolted together properly and it still wobbles, the spindle bearing (#21A-8626) is bad. I went through this recently and found that there are zero spindle bearings available anywhere. I located a used fan assembly from a local guy, it was the last one he had. About that time I saw a couple of used fan assemblies sold on ebay, with the shipping they were close to $100.00
  #35
Old 12-10-2014, 12:40 PM
Great schematic, I tried to crank it up last night but it made a clanging sound and stopped. I do need to find a complete assembly, but until then I will have to go with electric fan again.
  #36
Old 12-10-2014, 12:44 PM
Harleymsn, you are so right! I did not have the retaining backing plates! You would not believe how many answers I got from so many supplier experts! I cranked, I bent the pulley so I need to find a complete minus fan. If you find one, please send link to it.
  #37
Old 01-09-2015, 10:41 PM
I found one on EBay for $60, but now having trouble starting her up. Acts like it's going to fire but dies then floods. I drain bowl start again and does the same thing. Any suggestions think my points are bad. It just started up a few days ago in 10 degree weather.
  #38
Old 01-09-2015, 11:20 PM
ALBUQ F-1's Avatar
postin' fool
It sounds like the float is sticking open. Try rapping on the side of the bowl.
Fan shroud willowbilly3 1957 - 1960 F100 & Larger F-Series Trucks 4 07-01-2016 04:53 PM
Electric vs mechanical cooling fan 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 49 02-16-2016 08:31 PM
When did they start using a fan clutch? Nathan Plemons 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-13-2010 06:26 PM
bent fan blades bawrestler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-07-2007 11:12 PM
Fan Clutches for 4.9L SilverSport Ford Inline Six, 200, 250, 4.9L / 300 3 11-14-2006 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
