Fan for my 52 F5 - Page 2 - Ford Truck Enthusiasts Forums
Fan for my 52 F5
Old 04-23-2014, 09:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I'm running a Car 3-blade fan with shroud and have had no issues even in 100 deg weather. But I have spent a lot of time getting my block and radiator really clean.
Old 04-24-2014, 01:15 AM
gearhead1952's Avatar
gearhead1952 gearhead1952 is offline
gearhead1952 is gaining momentum as a positive member of FTE.
I have a four blade from an f1 and one from an f6. I need to look again but pretty sure the f6 fan has more than 4 blades
Old 04-24-2014, 11:44 AM
ALBUQ F-1's Avatar
postin' fool
There was a thread about this about 6 months ago if you want a good discussion of it.
http://www.ford-trucks.com/forums/12...-question.html
Old 05-06-2014, 10:42 PM
Joshua Farm Joshua Farm is offline
Joshua Farm is starting off with a positive reputation.
Anyone know size bolts?
Does anyone know the size bolts? I have located a matching 5 blade and have the metal ring, but no bolts to mount it on the hub.
Quote:
Originally Posted by harleymsn View Post
The parts book actually calls for a 5 blade (18.5" dia) part# B7Q8600C. The parts book shows ONLY 5 blade fans for all trucks 1948-56, so I wonder if the 4 blade was supposed to be on the passenger cars.
38 Coupe, I see you changed the pic you posted, where was that one from, as it indicated the fan part # to be 8602?
Anyhow, Part #B7Q8600c
Dennis Carpenter has 2 NOS
Klimesh Motor Sales Calmar, IA 52132 has 2
Miller Obsolete Binghamton, NY has 1 $90.00
Old 05-07-2014, 08:49 AM
harleymsn's Avatar
harleymsn harleymsn is online now
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
8 No. 12-32 x 1/16"
Old 05-09-2014, 12:16 AM
8 No. 12-32 x 1/16"
Thank you, but I am measuring 1/4 " holes by 28 fine thread. Does that sound right? Are you saying that the screws are only supposed to be 1/16" long?
Old 05-09-2014, 12:18 AM
8 No. 12-32 x 1/16"
Am I reading this right? 1/16" long?
Old 05-09-2014, 12:22 AM
1/16" long? I measure 1/4" diameter and 28 fine thread. I have another problem. The pulley for the fan is freely sliding from mounting hub. Is it supposed to do that? If not, how do I fix it?
Old 05-09-2014, 12:26 AM
harleymsn's Avatar
Quote:
I'm sorry, they are 1-1/16th
Old 05-09-2014, 12:31 AM
No problem, thank you so much for the specs. I could not find them anywhere. Do I have a major problem with the pulley? It slides freely from behind the mounting ring aft to the motor on the shaft. Something just doesn't seem right with this?
Old 05-09-2014, 12:38 AM
harleymsn's Avatar
Here is the list of screws and bolts for the assembly
EDIT: Just relooking at the chart, the 48-51 Big Job 337 fan hub had 1/4 x 28 thread x 3/4". Maybe somebody changed out the hub before, if so the parts list is just above the second group highlighted. I edited the picture.
Old 05-09-2014, 07:42 AM
I think your right, because it is a 239 and it had an electric fan on it. The pulley behind the hub is not firmly attached to the shaft. It does stop turning when I hold it up close to the back of the hub. It does look like there is a gasket between it and the hub.
  #28
Old 05-09-2014, 12:31 PM
ALBUQ F-1's Avatar
postin' fool
The fans on these are opposite from most modern setups. The shaft is held firm, and the pulley/hub/fan spin on that.
  #29
Old 07-15-2014, 10:12 AM
Quote:
I understand the spinning freely, but it slides back and forth along the shaft. The last thing I want to do is to put a belt on and throw the fan. It looks like there is a sleeve or something missing to hold it firmly on the shaft.
  #30
Old 07-15-2014, 10:32 AM
Yes, but the pulley is not held firm. It slides forward and back on shaft
Fan shroud willowbilly3 1957 - 1960 F100 & Larger F-Series Trucks 4 07-01-2016 04:53 PM
Electric vs mechanical cooling fan 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 49 02-16-2016 08:31 PM
When did they start using a fan clutch? Nathan Plemons 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-13-2010 06:26 PM
bent fan blades bawrestler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-07-2007 11:12 PM
Fan Clutches for 4.9L SilverSport Ford Inline Six, 200, 250, 4.9L / 300 3 11-14-2006 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
