49 Radiator
49 Radiator
I use to see advertisements for a 1949 FOrd F1 radiator with shroud and fan often but was no where near needing one in the build process. Now that I need one wouldn't you no luck would have it I can't find one anywhere.
I know I will get beaten about the neck and head for my next statement but I wil take the beating because i need the help..... Anyone know where I can find the Radiator with fan and shroud set up for a 350 motor? Looking for radiator tha twill fit in original radiator support.
Here's one on ebay that will fit into your radiator saddle and will accept the AT cooling lines. I have this in my truck and I used a 1970 Torino lower radiator hose (cut down, took me quite a few hoses to find one that would fit properly).
Aluminum Alloy Radiator Ford F1 F8 Truck Pickup w Chevy L6 V8 Motor Swap AT48 52 | eBay
Wally
Wally
Radiator
Looking for this setup with the shroud? How is your fan attached to the radiator?
Wally
Wally
Here is the original stock 1949 six cylinder radiator with original shroud, modified, and with the addition of an electric fan. The set up seems to keep the installed 350 cool. When running at road speed, I do not need the fan. I am running a large external transmission cooler to cool the 700R4 .
Wally
svooom
70
06-15-2007 10:48 PM
ksmith203
03-04-2007 02:07 PM
49willard
27
02-04-2007 05:05 PM
