300 oil pressure port
Old 04-15-2014, 01:00 AM
raven3's Avatar
raven3
raven3 is offline
There are two 1/4" NPT tapped holes in the 300 block towards the rear, one on the left side and the other on the right side.
Believe one is for oil pressure and the other of oil temperature or coolant temperature? Original sensors were electric wire.
Replacing with mechanical output sensors.
Looking for the block location for the oil pressure , coolant and oil temperature.
Maybe the coolant temperature is measured at the themostat housing on the cylinder head?
Old 04-15-2014, 09:47 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
On the driver's side there are two tapped holes that both go into the lifter galley. You can use the rear, the oem location, for oil psi, the other for oil temp. The tapped hole on the passenger side, toward the rear, is coolant. I use it for running temp. If you use the thermo housing for a temp sending location, your reading will run about 20* hotter than reading you would receive from the passenger rear block location.
Old 04-15-2014, 07:45 PM
raven3's Avatar
raven3
raven3 is offline
Is the drivers side forward block port normally factory plugged?
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
Engines with an EEC use the coolant port in the block for the gauge panel and another fitting in the water neck for the EEC temp sensor.
Old 04-15-2014, 11:12 PM
F-250 restorer
Yes. It is factory plugged.
Old 04-16-2014, 11:56 PM
raven3's Avatar
raven3
raven3 is offline
There are two 1/4" NPT ports on the right side.
Understand the rear more port is used on coolant temperature.
The forward port is plugged.
Is this a coolant drain plug?
kabcpapc
Modular V8 (4.6L, 5.4L)
09-06-2014 05:35 PM
86scotty
05-19-2014 09:51 AM
carmk
04-18-2012 08:27 AM
Blaster7Romeo
06-06-2008 09:44 PM
RedDawg
08-10-2005 03:56 PM
Quick Reply: 300 oil pressure port
