Marker lights above step bars and getting inspections - Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: Archion
Old 04-14-2014, 10:58 PM
ketel0ne ketel0ne is offline
ketel0ne is starting off with a positive reputation.
I have added 2 and am thinking of adding 2 more per side over the step bars. Has anyone gone through inspection with side lights? How about the 3 in the grill? The statute says:
WV Code Chapter 17C Article 15
17C-15-19. Additional lighting equipment.
(b) Any motor vehicle may be equipped with not more than one running board courtesy lamp on each side thereof which shall emit a white or amber light without glare.
OR
17C-15-12. Visibility of reflectors, clearance lamps and marker lamps.
(a) Every reflector upon any vehicle referred to in section nine of this article shall be of such size and characteristics and so maintained as to be readily visible at nighttime from all distances within five hundred feet to fifty feet from the vehicle when directly in front of lawful upper beams of head lamps. Reflectors required to be mounted on the sides of the vehicle shall reflect the required color of light to the sides, and those mounted on the rear shall reflect a red color to the rear.
OR
(c) Side marker lamps shall be capable of being seen and distinguished under normal atmospheric conditions at the times lights are required at a distance of five hundred feet from the side of the vehicle on which mounted.
Old 05-02-2014, 12:26 PM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
Most likely the inspector will only make sure that they work and not about the quantity.
Rod
Solution for Poor LED Tail Light Visibility WhiteEx 2015+ F150 10 08-11-2015 06:52 AM
deer hit repair - what lights do I want? willeo6709 1999 - 2003 7.3L Power Stroke Diesel 6 06-19-2015 10:01 PM
Upgrades... spectec7248 2009 - 2014 F150 13 01-29-2015 01:06 AM
no front side marker or parking lights 2005 SuperDUTYY brennandc Electrical Systems/Wiring 1 12-21-2014 07:21 PM
Different style cab lights, what you think? Ravenwood Ranch 1987 - 1996 F150 & Larger F-Series Trucks 4 11-22-2014 10:39 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
