Hey guys I'm posting this for work, I have a 7.3. Someone came in to the shop and said they couldn't get it to go into gear. So I go out and it says check brake system and the brake light is on. Also there is no lights what so ever. No brake lights, head lights, hazards, turns, nothing. I check all the fuses, and they're good. Change the brake switch, good. Change the headlight and multifunction switch, good. I'm at a loss and don't know what else to check. Any ideas would be appreciated. Thanks!
Check the SJB - Smart Junction Box - the fuse / relay / control panel in the passenger side footwell. It controls pretty much all the lighting, the shift interlock solenoid, etc.
