Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
1997-1999 Ford F250 Truck Light Duty (Under 8500LB GVW) Power Telescoping Towing Turn Signal Upgrade
Old 04-14-2014, 11:40 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
VISIT US HERE FOR GREAT PRICES
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!!
These replacement UPGRADE mirrors are just what you need to get your truck in good working form again!
Specifications:
Both LH (Driver Side) & RH (Passenger Side)
Specifically designed as UPGRADE bolt-on replacements for Light Duty trucks
'08 and up model Super Duty style
3 stud mounting
Has the following options:
Power upper mirror
Turn signal
Turn Signal wiring will be plug and play if original mirrors have turn signals. If the original mirrors you are replacing do NOT have turn signals, wire splicing may be required.
Dual telescopic arms
Textured Black housing
Direct replacement upgrades
Built to strict quality control standards
Instructions included
These mirrors are designed to replace the factory mirrors and will install just as the originals do. They make perfect replacements with great upgrades that have good cost savings over the dealer parts.
Brand NEW fitting for the following years and models:
2001-03 Ford F150 Truck (Except Crew Cab) Power Telescoping Turn Signal Towing Upgrade Mirror Pair
2004 Ford F150 Truck Heritage Model Power Turn Signal Telescoping Towing Upgrade Mirror Pair
1997-00 Ford F150 Truck Power Telescoping Turn Signal Towing Upgrade Mirror Pair
1997-99 Ford F250 Truck Light Duty (Under 8500LB GVW) Power Telescoping Towing Turn Signal Upgrade Mirror Pair
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
1Aauto
01-27-2017 02:17 PM
1Aauto
07-02-2014 03:00 PM
1Aauto
06-10-2014 03:25 PM
1Aauto
03-25-2014 10:30 AM
Quick Reply: 1997-1999 Ford F250 Truck Light Duty (Under 8500LB GVW) Power Telescoping Towing Turn Signal Upgrade
