Hidden Fuel Gauge Completed
Well just to put an end to my fuel gauge project I'm doing this little write up on the gauge part of the install. (Actually I'm striving for my third green dot kinda like a patch in Scouts but...nothing wrong with trying to do good....shhhhh.)
So here are the parts of the ash tray. The bare metal plate is for gauge mounting and to block off the ash tray hole.
Next is the new plate test fitted into the dash.
Now I've cut the gauge hole in the plate roughly. I'll go back with a dremel and smooth it out some.
Had to make a bracket to hold the gauge in. Also bent it so it would be a little short and hold the gauge in tightly. If you will notice I had to turn the gauge 90 degrees to have room for the mounting tabs. Space didn't allow the tabs to go side to side. Just too narrow.
Here's the panel is assembled to test fit before painting. Rivets were removed so the panel could be painted.
Panel after painting. This is the closest spray can paint I could find to my truck color. It's going to be hidden so its not THAT big of a deal.
And here it is mounted in the dash. I'll be getting some new hardware to replace the old mounting screws that I don't like so much. Also will paint the rivets red to match.
To get the original door back on and cover things up I disassembled the ashtry. The door slips out of the groove in the bottom and is held in by the screw on the ****. I put some magnets on the door to hold it on. They have no problem staying on bumping down the road. When I need a quick look I just pull the door off and check out the gauge. It's a snap. Looks factory and was easy to do.
Thanks for looking!
Thanks for looking!
A hinge was the original plan but this is so easy I'm counting it as done. Thanks for the reply Nick!!
Heck no I don't mind. I've gotten so much from this board I'm just trying to give back. Here's a tip I didn't mention. To make the new plate just lay the part that unscrews from the dash down on some 18ga sheet metal and trace it. Mark the mounting holes and all. I used my Dewalt jigsaw with a sheet metal blade to cut it....like butter. Good luck with it.
I guess if that works for you...okay. Nice work. However, I don't think I understand the reasoning for hiding the gauge. Why would you not want to have the gauge in plain sight all the time? Out of sight is out of mind and I'd always want to be cognizant of my fuel level...
It's a fuel gauge not a tach or speedo. I don't fill up but once every couple weeks so I don't hardly have to ride down the road looking at my gauge. I'll check it after a few days just to see. It takes a whopping 2 seconds to look. It beats the heck out of what i had which was nothing. Don't send me to the "how many forum members does it take to screw in a light bulb" thread...lol. I was simply showing what works for ME. And to further my point....I DO NOT want a modern Autometer gauge showing in my truck. I had it on the shelf and it saved me buying a $60 gauge. It's removable and takes 5 minutes to return to original. Seems like a win win to me. And to further my point again...."out of sight out of mind" is not in my nature. I'm very detailed. Nothing leaves my mind unfortunately. I take meds for that but they are still there DANGIT!!!
Thanks for the reply!
