2003 Excursion 7.3 question - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-13-2014, 10:58 PM
truck7575's Avatar
truck7575 truck7575 is offline
truck7575 has a good reputation on FTE.truck7575 has a good reputation on FTE.
OK, so i need to replace my timing cover, I know this is a HUGE Job so with 315000 on the clock I was thinking maybe ill just pull the 7.3 (it runs great btw) and throw in a reman 7.3 long block while im at it. What are everyones thoughts on this? Should i replace the engine while i have it out? When I am pulling the engine what are the minimum number of things i have to take off the top of the engine in order to get the engine out of my excursion? Any advice?
Old 04-15-2014, 01:20 AM
truck7575's Avatar
Anyone have any input?
Old 04-15-2014, 04:01 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
First question would be why or how do you know you need to replace the timing cover?
Only things off the top of the motor to pull the motor would be the turbo and pedestal, as well as the intercooler pipes. Unbolt the A/C compressor, but leave the lines hooked up and hang it over the fender with the evaporator coil, it will reach, and keep you from having to recharge the system.
Old 04-15-2014, 08:48 AM
truck7575's Avatar
The water pump will not seal to the cover because the sealing surface on the timing cover is almost completely corroded away.. Heavy amounts of sealant are required to keep it mostly sealed... Going through about a gallon of coolant per week
Old 04-15-2014, 10:37 AM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
Is the coolant leaking on the ground or in to the oil? If it is in the oil you may want to consider dropping a reman motor in. If it leaking on the ground only I would run a compression test and if it had no unusual knocks or ticks just swap the cover.
Old 04-15-2014, 11:00 AM
SteveH-CO SteveH-CO is online now
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
If the compression is good, I'd replace the cover. You might still want to pull the engine to replace every gasket, however, since now would be a good time to do that.
Old 04-15-2014, 01:09 PM
countrycar's Avatar
countrycar countrycar is offline
countrycar has a very good reputation on FTE.countrycar has a very good reputation on FTE.countrycar has a very good reputation on FTE.countrycar has a very good reputation on FTE.
I think this is what your looking for.
As stated before, if your compression is good, heads are tight and your not using oil etc, then no need to replace the motor. Just replace timing gear cover. There are other on Ebay, or even at your local junk yards for around $90.
Old 04-15-2014, 01:40 PM
BigAlsPSD's Avatar
Oh, ok...front cover, Clay sells them by the way too Engine Front Cover 97-03 - Riffraff Diesel Performance
As others stated, I would do a compression test before removal to know, and if all checks out good numbers and even wouldn't hesitate at all to put the motor back in.
Old 04-22-2014, 02:32 AM
truck7575's Avatar
The coolant is not leaking into the oil, i was kind of thinking the same thing... if i get it out and the compression is still good just replace cover and put it back in.. at 315000 i figure i can get it to 500K without a rebuild. Anyone had any experience with changing the cover without taking the engine out of the truck... just lifting it enough to get blocks under it and dropping the oil pan to get the cover off
Old 04-22-2014, 09:46 PM
truck7575's Avatar
any recommendations on what i should replace just because i have the engine out of the truck? I already did the intl bellowed up pipe replacement and i have already rebuilt my turbo with a wicked wheel 2, ive already done everything on top of the engine, injectors harnesses glow plugs, HPOP (t500) Rebuilt the fuel bowl, hpx oil crossover, frx fuel pressure upgrade. any other suggestions.
Old 04-22-2014, 09:53 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
It would be a good time to replace the o-rings in the dipstick tube adapter and oil cooler. Sure beats laying on your back to do those.
Old 04-23-2014, 12:02 AM
nookiemonster55 nookiemonster55 is offline
nookiemonster55 is starting off with a positive reputation.
you doing this yourself?
Old 04-23-2014, 10:51 AM
truck7575's Avatar
Yes... Was gonna pull it myself... I thought about posting on here and inviting a bunch of guys from on here down to help on a weekend and having free beer and a cookout and anyone who wants to stay can swim and camp out in my backyard... I can fire up the fire pit... I am able to do it myself... I've never pulled a 7.3 but I've pulled a jeep 4.0 inline and tranny and I've redid the whole top of this engine down to the heads so pulling that stuff off again is not foreign to me... Of course would take me a lot longer to do it myself... Wonder if anyone would come help... I have access to an engine hoist but not an engine stand
Old 04-23-2014, 11:21 AM
Pikachu's Avatar
You'll want a stand. To do the front cover, the oil pan needs to come off. The best way to reseal it is upside down on a stand so you can get it clean for the sealant to work well. The Harbor freight 2,000 lb stand works just fine for the 7.3 and it's relatively inexpensive at $129. There are usually 20% or 25% off coupons in the Sunday papers, so that would help too.
Old 04-23-2014, 11:37 AM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Georgetown where?
Looking to buy a 7.3 Excursion e55driver Excursion - King of SUVs 27 01-06-2016 09:54 PM
7.3l Ex. Fuel Level Sending Unit Pigtail Pinout HaydenFryGuy Excursion - King of SUVs 0 09-21-2015 08:16 PM
7.3 PSD engine installation - pics and description SkySkiJason 1999 - 2003 7.3L Power Stroke Diesel 20 12-24-2012 09:22 AM
Buying used 7.3 excursion ?'s Splatts Excursion - King of SUVs 47 01-07-2012 12:33 PM
Muffler Delete for 2002 7.3L Excursion? SC-Ex Excursion - King of SUVs 39 03-17-2010 12:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
