2005 f150 5.4 3v power mpg upgrades
Hi I have a 2005 F-150 Lariat 5.4 3v. I have a Spectre CAI, 2 Flowmaster Super 10 Mufflers, Magnaflow high flow cats, Afe Throttle body spacer.
I'm wanting to get some more power and better mileage. "Supercharger and Turbo isn't an option unless its used for about a grand" I'm leaning towards underdrive pulleys, longtube headers or "shorties if there's any problems or major modifications for longtubes" and Sct X4 from 5 Star Tuning with custom tunes for my performance mods so I would get that after I get my upgrades on.
I don't know what else there would be for this truck I don't want heads or cam or anything like that I'm only looking for bolt on's? Would the Mods I mentioned be pretty good? Is there any problems putting on longtubes? Any difference in power LT vs Shorties?
I was thinking about putting a single muffler on also Dual in/Dual out since mine is true dual maybe having one muffler would increase HP/TQ?
Any information or answers to my questions would be great help. Thank you.
Ok i will try that. I sent back my TBS but I got the SCT x4 installed with custom tunes. I got the 91 performance tune on now I usually run 89 but trying new things. Gonna try the 89 economy next fill up but it shows where i can change global timing, timing at wot, AFR at wot, shift press, shift at + or - miles other than normal. Not sure what i should set any of it at dont wanna mess things up.
From the research I've done and the threads I've read, your true dual exhaust us probably the biggest killer of power and mpg. I very much want a similar setup except with super 44 and a h pipe but until I do my 4.88 gears I don't want to sacrifice any power.
What gears do you have? Changing them can help with power and mpg
If you have true duals, you'll pick up some power just having a balance tube welded in (making an H pipe) and it will sound better.
Question about crossover pipes on dual exhaust | The H.A.M.B.
The old hot rod trick is to paint a section of exhaust white just after the heads/manifolds and go drive. The spot that it's burned off the most is where to put the tube.
fordfarmer12
1999 to 2016 Super Duty
13
03-14-2012 03:25 PM
boatcop1
1997-2006 Expedition & Navigator
25
07-19-2007 03:25 AM
